Lean Misfire or??
ALDL cable & software package (plus a laptop) so you can see/log more of what's really going on. AKM has
a reasonable price on DataMaster+cable - check the references on this page for his URL.
Since you have recently replaced the injectors, lean mis-fire seems like the least likely problem - at least
as far as the injectors go. In a car of that age the EGR valve will also need to be replaced more often than
not... that could cause some of the symptoms you describe.
If the car ran with faulty injectors for some time, I would worry more about burned valves. I would do
(or have done) a compression/leak-down test first, to see if anything major was damaged. Then I would
check the exhaust headers for back pressure - to see if the cats were melted or plugged. If those tests are
OK then I'd look further for the source of the misfires with the logging software. Some areas to look at
include:
If they are still original, the fuel pump/sock/filter/regulator diaphram all need checking; as well as the
wiring and connectors closest to engine heat.
The ECM injector drivers are current-limited and fuse-protected, so blowing one would not be easy. But,
if the ECM is original in your car it is a 13+ year old circuit board. It couldn't hurt to pick up a spare and
have it on hand - they don't last forever, especially if it spent some portion of its life sitting outdoors...
The pulse-widths you listed sound normal. Looking at the engine in the driveway only gets you info on the
idle timing - you need to log some data on the road to get a better idea of what the whole system is doing.
HTH
Joe Valentine
It doesn't seem right at first, but it is normal.
MIke
http://forums.corvetteforum.com/show...post1545625829
That one didn't mention DFCO or DE, but those are the fuel subtractions that lead to the 0.0 PW on deceleration.
Quite a bit of reading material is available if you want to dig deeper into the fuel loops for $8D:
The commented $8D code has been in the public domain for 10 or 12 years. A copy of the complete text file can
be found here, under 'Source Code & Hacks" :
http://www.moates.net/fileman
A short discussion of PW calculation by itself is going on here:
http://www.thirdgen.org/techbb2/show...hreadid=255308
A recent effort at a newly commented hack (with disassembler & compiler info) is here:
http://www.thirdgen.org/techbb2/show...hreadid=245659
Ken Canata posted a very good description of how GM code interpolates a 3-D data table here:
http://forums.corvetteforum.com/showthread.php?t=547494
There is a GM engineering document with part of the programming description for a Turbo Sunbird around somewhere -
but I can't lay my hands on the URL just now. The code is for a 727 ECM and is similar to the 8D. If you want the
file send me an e-mail.
HTH
