Lingenfelter 219 cam help needed
Old Sep 22, 2004 | 03:13 PM
  #41
JAKE's Avatar
JAKE
Originally Posted by scorp508
Sounds about right, otherwise you end up digging into the gaskets.
It's best to use the recommended torque for the intake system you're installing.
My manual shows the intake to head torque setting to be 25-45 ft.lbs. on one page, but on another - where many other torque specs are listed in a column - the spec is 35 ft.lbs.
Since I've been screwing on these engine for a lot of years, I have developed sort of a "feel" for torque. Pulling the intake bolts up to 45 ft. lbs into aluminum heads pegs my nervous meter, even though the bolt holes are heli-coiled. So I chose the 35 ft. lbs. setting rather than trying to pull them to 45.
I've never been able to find the spec for the intake manifold RUNNER bolts, so I use 35# there too and my nervous meter never went off as I was doing it. 35# is probably at the high end of the range though.
20 ft.lbs. seems low, but, absent any contradictory information, I'd go with it too. The runner bolts are of a smaller diameter so, theoretically, require less torque. I just hit them over and over to make absolutely sure that 20 holds.
Jake
Old Sep 23, 2004 | 06:25 PM
  #42
rrubel's Avatar
rrubel
I'm NOT nuts! Reason for the bad leak... I have two left runners. I called LPE today and spent a while on the phone with Tim Dyer (need to buy HIM a beer after all the q's I've asked...). He got a set from somewhere and looked at them and we confirmed that I have two of the same runner. It's also obvious looking at the gaskets sitting over the egr ports that one doesn't fit... leaves about a 1/2" hole outside the gasketed area . Bad assumption on my part, I guess, that I had been sold all the right pieces...
Anyway, project has to go on hold for a week or so while he tries to get Accel to send me a new pair on exchange without charging me.
Maybe now it'll work...
[RICHR]
Old Sep 23, 2004 | 06:33 PM
  #43
scorp508's Avatar
scorp508
Originally Posted by rrubel
I'm NOT nuts!
Lets not go THAT far! Glad you found something.
Old Sep 23, 2004 | 06:45 PM
  #44
rrubel's Avatar
rrubel
hey Hey HEY! All the shrinks swear up and down that I'm clinically sane! Or was, at least, when they let me out. .
Gah, I just want this project OVER with. It feels like a bad government contract at this point.
[RICHR]
Old Sep 23, 2004 | 07:00 PM
  #45
JAKE's Avatar
JAKE
Don't feel too badly about it. I've lost count on how many times we've suggested to others to check certain things, then to have them come back and post that "everything was checked and is "fine".
Then, later on, he posts that the very thing he said was "fine" WASN'T and it was the cause of the problem.
The he apologizes for causing all the confusion.
Just seems to happen a lot for some reason that I still can't put my finger on.
Jake
Old Sep 23, 2004 | 07:08 PM
  #46
LD85's Avatar
LD85
[RICHR]
This has been interesting to follow, I have been debating on pulling my MR and putting on a Superram, this is an eye opener since my projects usually go like yours is going
Didnt you used to live in Southern Indiana?
Just remember, whomever said "third time is a charm",,, never did it 4 times
Old Sep 23, 2004 | 07:19 PM
  #47
JAKE's Avatar
JAKE
I just noticed you're at Indy. I drove up there for Super Chevy weekend in July. A buddy of mine - one of the teams I use to build engines for - was running a Yellow Monza.
Sorry I missed you 'cause I KNOW you were there.
Jake
Old Sep 23, 2004 | 08:39 PM
  #48
rrubel's Avatar
rrubel
Biggest suggestions I can make... 1. Bite the bullet and pay to buy the parts new from Lingenfelter. Anything wrong or missing, they'll take care of it no problem. I bought mine new from a list member who decided not to mod his engine and that's caused some issues. 2. Given the choice between the SR and an LT1 intake for my L98, I think I'd *still* go with the SR, but go about its installation differently.
My dad does. That's probably who you're thinking of.
Great line...
Scorp508 - you said your SR has the bolts inside the plenum. What kind of heads do they have, what size are they, and how do you space them away from the walls of the plenum? I'm having spacing issues to the point where we're not going to modify the 8 outer bolts and there's some question about two of the inner ones.
[RICHR]
Old Sep 23, 2004 | 08:51 PM
  #49
scorp508's Avatar
scorp508
ONLY the large inner 4 bolts. Not the small 12-point perimeter ones. In my opinion there isn't enough space to redo the perimeter ones. Maybe studs could be welded into place, but I doubt it.
Old Sep 23, 2004 | 09:00 PM
  #50
rrubel's Avatar
rrubel
Um. Originally, all the bolts were those small 12-point ones. Obviously yours have been replaced by bigger ones
The two that I *really* want to do are the inner driver's rear (by distributor cap) and inner passenger front (by TB) so I don't have to pull those two items to take the plenum off. We're investigating allen-head bolts like smaller versions of what holds the runners to the manifold.
[RICHR]
Old Sep 23, 2004 | 09:38 PM
  #51
scorp508's Avatar
scorp508
Yep! God it only took 2 years for me to realize it!
*edit*
Can't exactly remember the size of them, but they're just a six-sided bolt head.
Old Sep 24, 2004 | 12:31 PM
  #52
sothpaw2's Avatar
sothpaw2
Default almost over--light at end of tunnel
Love that Quote.
Rich,
Sorry to hear you are having so many woos with this set-up. But I'm convinced from reading this that you should see the light at the end of the tunnel bright and clear.
You have been vetteless for tooo long IMHO. Maybe some weekend morning you can come over and we can visit a nice windy road. I have cones too. I have discovered, that is the best use for a Corvette. There are a lot of Country, curvy roads here.
Old Sep 24, 2004 | 11:59 PM
  #53
rrubel's Avatar
rrubel
Man, I HOPE so...
Yes, please! And how was your track day? I'm going to have to reschedule mine unless you'd like to loan me your Vette .
[RICHR]
