Good question.
I am trying to figure this out as well. Some claim HP gains , others say its bogus and only done so that we can add to the mods list.
Does anyone have the definitive answer?
There is no definite answer. Vetts from up north need the heat to keep
the TB and everything else from freezing up during winter. Florida cars
don't need the little extra heat. As far a gains, the vette is engineered to run with heat for EPA and many other things. The gain from 1 degree
reduction in heat is very very small, it any.
When I first got my Vette, I thought the bypass sounded good to me so I did it. After reading a lot about this mod, it's really a no gain as the whole engine warms up anyway. If I were to go up into the cold country, I'd hook it back up. Still, the idea of hot coolant running through the TB just seems like a horsepower robbing thing. I don't think you'll gain anything, you just won't lose anything. Here is a thought, what if your coolant was cooler than the engine temps near the TB? Wouldn't that increase your horsepower due to the cooling effect? Hummmmmmmmmmmmmm.
Since I did the TB bypass mod, my intake doesn't get anywhere near as hot as before.. Aven after an hour of driving, it is still only wamr to the touch, instead of being superhot before.. Worth it for me..
I don't think there will be much gain from this one particular mod, but all the little ones will add up. Also, makes the R&R of the throttle body a lot less messy.
I think that the above posts pretty much hit the nail right on the head. The bypass is definitely beneficial when it comes time to remove the TB - it would make it much easier and quicker. In terms of the cold weather necessity, I dunno. How many cars *don't* have coolant running through the TB from the factory? At least a couple I've owned. Do those cars function in cold climates? Yes. However, if GM put it there, it must've been for some reason, so I won't go any further.
As for performance loss, heat is bad - yes. However, how much heat will be actually transferred to the air rushing through the TB just before it enters the plenum? Probably not nearly enough to make a noticeable difference. The warmer underhood air that the engine draws in at idle has already maximized any "heatsoak" that could occur. At highway speeds, I believe the air is rushing by far too fast to accumulate any significant heat gain which could rob HP.
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
This mod is to simple not to do in a warmer climate (I'm in Florida). I also have this mod done on my sportbike; it's one of the mods Honda uses on their race bikes and is part of thier setup manual for the track. This mod along with some other simple mods made a noticeable difference on the dyno for my bike. I believe there is a difference for Vette's also.
Just remember there is no need for a fancy kit when a longer hose from your local auto parts will do the same bypass
the outside air temperture has nothing to do with potential TB icing. The amount of moisture in the air is what can ice with the presure drop across the TB.
it can be 100 degrees outside, and if you have enough of a pressure drop, the air will drop out the moisture, and you will form ice in the process.
70F is about the upper limit for icing. The airplane faeries have lots of experiance and knowledge on this topic from close to a century of dealing with carb icing.
Just so you know, jets use 50degreesF or 10degrees C and lower and visible moisture (clouds,rain, snow, fog, etc) as a guide to turn on anti ice equipment. So if I were driving around with the temp below 40 or so and some moisture around, I'd probably avoid the bypass.
one day..., 92 degrees F inside my factory, I was draining the BIG air compressor for maintance. 175psi down to zero. there was a thick layer of ice where the air was hitting as it was draining.
I say if the conditions are right, you can form ice at any temp.
having said that, I did the TB bypass on my F-body, never a problem.
There is a big azzed difference between the 175 psi pressure drop you were working with and the less than 15 psi pressure drop you can get in a throttle body. You can't ice up a throttle body in 70F plus weather.
