TPI questions
Old Aug 19, 2004 | 01:03 PM
Heretic's Avatar
Heretic
Default TPI questions
I have a TPI intake of a 1991 Camaro that I want to install on my 1991 K5 Jimmy.
Performace wise I just want torque and lots of it. Are high dollar runners worth it for an engine that won't go over 4k RPM? What about cams, is there a flat tappet grind thats recommended for TPI?
Any other advice pointers etc?
Old Aug 19, 2004 | 01:40 PM
JAKE's Avatar
JAKE
My take on this is that aftermarket runners serve to improve engine breathing at higher RPMS, as opposed to the stock ones. So if you are after low-end torque, I'd stick with the stock runners and spend the $ elsewhere.
There are a lot of flat tappet cams on the market specifically designed for the TPI setup. You can go to CompCams website to check them out. Look for their Xtreme Energy series of flat tappet cams.
I'd keep the .050 duration at 210 or below (something on the order of 208 In/212 Ex @ .050) and the lobe seperation angle at 112.
Just my thoughts.
Jake
Old Aug 19, 2004 | 02:40 PM
CFI-EFI's Avatar
CFI-EFI
Jake
Except possibly even MORE LSA, if available.
Flat tappet? Doesn't a '91 Jimmy come with a roller cam? If it is a 305, you might want to chop a few degrees off those .050" duration numbers.
RACE ON!!!
Old Aug 19, 2004 | 11:49 PM
vader86's Avatar
vader86
The AS&M runners or the like is up to you, a bigger base is preferable to the runners to me.
The Lingenfelter 211 or TPiS ZZ9 cams are suited to TPI motors.
Old Aug 20, 2004 | 08:32 AM
Heretic's Avatar
Heretic
Thanks for the pointers. I think I'll just leave the runners stock and port the base and plenum a bit.
As for the flat tappet cam, trucks did not come with rollers until 96. Every once and while you'll luck out and get a block machined for a roller, but with the flat tappet cam installed. My last 91 K5 (RIP) was not a roller block even.
To TPI questions
