ZF Release bearing question
Old Aug 19, 2004 | 07:07 PM
LD85's Avatar
LD85
Default ZF Release bearing question
Can you change the Release Bearing (throw out bearing) with the Pressure Plate on the car?
I will find out for sure on Friday but, wondered if anyone had done this.
TIA
Old Aug 19, 2004 | 08:01 PM
Dale1990's Avatar
Dale1990
St. Jude Donor '15
I think you can. It is only held in by a spring ring around its perimeter if I recall. If not, it is only a couple of bolts to remove since the tranny is already out.
Can you even buy just the TO Bearing? I had to buy the entire pressure plate - glad I did since the springs were pretty weak.
Old Aug 20, 2004 | 07:17 AM
LD85's Avatar
LD85
Yes you can buy the release bearing seperatly.
I just wonderd if the clamp load on the Pressure Plate as it is clamped down , interferes with the removal of the bearing.
Old Aug 20, 2004 | 10:37 AM
LD85's Avatar
LD85
Upon further review, no you cant.
Old Aug 20, 2004 | 09:30 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
So does the bearing back up to disengage the clutch? Interesting.
Old Aug 20, 2004 | 09:43 PM
LD85's Avatar
LD85
Yes,,,, when it is relaxed the pressure plate is putting pressure onto the disc, when the clutch slave pushes towards the front of the car, the fork will pivot and pull backward to disengage, and realax towards the engine when it is enaged with the disc
Since the TOB is pulling backwards, there is a flange on the Bearing that touches the back face of the PP fingers, making the TOB OD larger than the clutch fingers.
ALso, the TOB for 89-93 is 3.175 ID and the 94-96 TOB is 3.110 ID
Also, the 94-96 has a plastic sleeve in the TOB ID that makes contact with the tranny tube that is over the input shaft.The 89-93 is all metal in the ID.
Old Aug 20, 2004 | 09:59 PM
Stingray1970's Avatar
Stingray1970
When I bought a new pressure plate for my 91 from GM it came with the late style bearing and I had to change it. The early bearing is available from GM part # 10203567. Just remember that the bearing lever ball stud is a left hand thread (turn it to the right to loosen) looking at the face of the bell housing. Hope this helps
To ZF Release bearing question
