ABS chatter around corners?
Old Aug 20, 2004 | 09:08 AM
Jim85IROC's Avatar
Jim85IROC
Default ABS chatter around corners?
Yesterday I was late for my flight so I was cooking through some twisties on the way to the airport. I took a very tight turn at a fairly high rate of speed, and tapped the brakes. When I did, I got the ABS chatter until the car straightened out. All I could think of was that the tight turn caused the wheel speed between the outer and inner wheels to be significantly different, making the ABS think I was skidding. Is this normal for it to do this? This is only the 2nd time I've even had the ABS do anything, but last time it was when I whoa'd up very quickly on a wet road, so it was understandable.
So... is this typical or is my ABS FUBAR'd?
Old Aug 20, 2004 | 07:02 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Sounds like it could be normal, you didn't tell us how fast you went into the turn and how hard you pressed on the brake pedal or for how long
My ABS ('88) only seems to "light up" when I really get on the brakes at speed. I "tap" the pedal a lot to just scrub off a little speed (say 75/80 to 70/65) and don't get ABS flutter!
How fast were you going anyway?
Old Aug 20, 2004 | 07:04 PM
Wheelman's Avatar
Wheelman
I have never had my abs come on at a very high speed, and I often drive fairly agressively. It only seems to come on during VERY HARD braking (ie. 60-0 tests) and when it is wet at lower speeds when a slick spot or gravel is encountered.
Old Aug 20, 2004 | 11:14 PM
comp's Avatar
comp
they could have been doing their job, have you tested them lately????
Old Aug 21, 2004 | 08:07 PM
Dale1990's Avatar
Dale1990
St. Jude Donor '15
Mine do that, too. If I wind up entering a turn too fast and have to hit the brakes a bit, the ABS will usually flutter a bit. I assumed this was normal.
Dale
Old Aug 22, 2004 | 12:37 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
The system on on my 86 has a lateral (g-force) sensor mounted under the center console. Not sure of its function. But one would assume lateral force input is a consideration when braking.
-JRC-
Old Aug 23, 2004 | 12:18 AM
white90conv's Avatar
white90conv
If the inside wheel hit a small bump, it may have come off the road or slightly skidded. This would set of the ABS. In normal driving on rough roads, the ABS frequently goes off if I hit the brakes, even lightly. I doubt that you have a problem.
Old Aug 23, 2004 | 09:08 AM
SilverBeast's Avatar
SilverBeast
St. Jude Donor '05
Mine does that too. No noise, but the ASR light flickers on.
To ABS chatter around corners?
