"SYS"? What the heck is "SYS"?
Old Aug 20, 2004 | 10:53 AM
JCD's Avatar
JCD
Default "SYS"? What the heck is "SYS"?
So last night I put my passenger side glass in (yay), so I went for a test drive, I noticed that every 20 seconds or so the MPG reading lights would flash "SYS" twice then return to normal. I didn't notice it on the way to work this morning, nor could I find anything in the shop manual under section 8, nor did any of the warning lights come on...
Does anyone know why my car was upset?
Old Aug 20, 2004 | 11:12 AM
LPDesRoche's Avatar
LPDesRoche
It will flash SYS when there is a CCM problem detected. Which can be caused by all sorts of things: low battery voltage, removal of Bose system, etc. If it is not doing it right now I would not really worry about it, the problem must have corrected itself.
Old Aug 20, 2004 | 11:13 AM
Steel Blue 91's Avatar
Steel Blue 91
I'm betting you didn't disconnect the battery while you were working on the door - interior lights on and maybe radio too? If so, your battery may have discharged enough to cause the SYS light to flash. It may have been weak to start with.
Old Aug 20, 2004 | 03:07 PM
JCD's Avatar
JCD
Ha, I bet you're right! It cranked low the first time too!
Thanks!!!
Old Aug 20, 2004 | 04:22 PM
greenvette95's Avatar
greenvette95
St. Jude Donor '03
Your battery is about to go south.
Old Aug 20, 2004 | 04:49 PM
Tony.96LT4's Avatar
Tony.96LT4
Mine cleared up till we were about to hit the FLA Keys. Then it died at the gas pumps. Walmart was only 1/4 mile away. If your battery is over 4 years old get a new one. Cheap insurance.
To "SYS"? What the heck is "SYS"?
