Spark advance question (LT1)
Old Aug 20, 2004 | 06:22 PM
STEVEN13's Avatar
STEVEN13
Default Spark advance question (LT1)
Hi,
I have been chasing a code 43. I looked in my shop manual but can not find what the spark advance should be on a 1992 LT1.
With my Autoxray scan tool it shows at idle spark advance at 23-24 degrees with 0 knock count.
When the (code 43) comes on, the knock count goes to 1-2 degrees and when I rev the motor spark advance goes up to 39-41 degrees.
This isn't right is it?
Thanks,
Steven
Old Aug 20, 2004 | 07:45 PM
Lone Ranger's Avatar
Lone Ranger
I would also ask this one over in C4 Scan & Tune, lot more guys there have scanners and software etc.
Old Aug 20, 2004 | 08:00 PM
STL94LT1's Avatar
STL94LT1
Default Stock Spark Advance.
I just check a stock data log from my 94. Spark advance at idle was 19*-21*, and 39* at WOT.
Old Aug 21, 2004 | 12:08 PM
STEVEN13's Avatar
STEVEN13
Just wanted to add something,
Sometimes with the Engine light on (code 43) the Autoxray shows 0 degrees of knock retard and normal spark advance (timming). Other times (with light on) it shows 1-4 degrees of knock retard. When light is off everything scans normal.
Thanks!
Steven
Old Aug 21, 2004 | 04:23 PM
ittlfly's Avatar
ittlfly
Are you running headers? If so, I have heard that the knock sensors may be picking up some of the vibrations. I'm running JBA shorties and have had my 92 throw code 43 several times. I changed out both sensors and so far so good.
Old Aug 21, 2004 | 08:04 PM
STEVEN13's Avatar
STEVEN13
ittlfly,
Thanks!
Running stock exhaust. However there is a slight exhaust leak.
I have been chasing this for a while now. I thought it could be the wires as they were arcing. When I changed the wires with Taylors 8mm it was fine for the first drive (about 1 hour) next day light came back (code 43). I noticed that the new wires were also glowing and arcing in some places. And yes all the wires are neat and not touching anything. I called Taylor and they said it could be a bad set and to return them. Now I am going to try a stock set of A/C Delcos.
Also I checked the circuit and all checks out.
Thanks again,
Steven
Old Aug 21, 2004 | 08:13 PM
bogus's Avatar
bogus
timing advance is a function of the optispark.... makes me think it could be weak.
Old Aug 21, 2004 | 10:56 PM
STEVEN13's Avatar
STEVEN13
Bogus, the opti is 3 years old and vented. Any way to check the opti?
Thanks for replying!
Steven
Old Aug 22, 2004 | 09:19 AM
Nathan Plemons's Avatar
Nathan Plemons
The computer only knows what it commands the spark advance to be and has no way to verify what it really is. If it shows a higher amount of a advance that is causing the retard, it is not the opti.
You have to look at all the conditions involved when the retard occurs. What is the MAP pressure like? RPM? Coolant Temperature? Intake Air Temperature?
Unfortunately the spark advance / retard functions are complicated.
To Spark advance question (LT1)
