Alternator Question
Old Aug 21, 2004 | 10:02 PM
mikey whipreck's Avatar
mikey whipreck
Default Alternator Question
My alternator usually hangs between 13.9 (idle) and 14.5 (cruising)... But once in a while it jumps to around 17 (?!). I've been told a few things that may cause this, but what are your guesses?
Old Aug 21, 2004 | 10:53 PM
BlkMagik's Avatar
BlkMagik
Regulator taking a dump maybe?
Old Aug 21, 2004 | 11:50 PM
mikey whipreck
I would think that would cause the volts to drop low, but could it send em higher as well?
Old Aug 21, 2004 | 11:56 PM
SPEED750's Avatar
SPEED750
Alot of things can make the voltage drop, but only the regulator can make it rise that high.
Old Aug 22, 2004 | 12:00 AM
mikey whipreck
Really? Can you get a regulator checked?
Old Aug 22, 2004 | 12:10 AM
jfb's Avatar
jfb
The voltage regulator causes this and since it shows up randomly, how would you show anyone that it does this? Just replace it, or replace the alternator. 17 volts can damage the MOV (metal oxide varistor) on the piggyback switching supply on one of the cluster circuit boards. Its job is to turn on and blow the fuse if the input voltage goes too high.
Old Aug 22, 2004 | 12:20 AM
mikey whipreck
Good to know... I'll see if I can get the regulator replaced then...
To Alternator Question
