L98 Perf Upgrade
Old Aug 22, 2004 | 01:34 PM
lefoy84's Avatar
lefoy84
Default L98 Perf Upgrade
I pulled the L98 from my 86 to freshen it up. I would like to get it in the 300HP range. Any suggestion? I already have a set of headers and a true dual exhaust with no cats and flowmasters.
Old Aug 22, 2004 | 02:17 PM
vader86's Avatar
vader86
The headers and exhaust should already have netted about 20-25hp.
You should look at Vic'89s setup closely if you only want 300 or so.
You would need a better base manifold, TPiS or Accel, a fully ported plenum and a bigger set of runners like AS&M. If you already have the engine out, you could change the cam now to something with similar specs to the Tpis ZZ9 or LPE 211.
(these are rollers, 86 is not a roller cam, its a hyd flat tappet)
If you have an Iron head engine, you should really replace those with something better, but you dont really have to to get this power level.
Old Aug 22, 2004 | 03:50 PM
lefoy84's Avatar
lefoy84
I am new to this Forum. How do I find Vic'89s setup. It does have cast iron heads.
Old Aug 22, 2004 | 04:36 PM
lefoy84's Avatar
lefoy84
I have access to a set of aluminum heads from an 86 L98 and a set from an LT-1. What is the difference and which ones should I get?
Old Aug 22, 2004 | 05:11 PM
SupaVette's Avatar
SupaVette
Hmmm i stand under correction but as far as i know the LT1 heads have difrent cooling passages to the L98's. But i could be wrong. :/
Old Aug 22, 2004 | 05:41 PM
vader86's Avatar
vader86
LT1 heads wont work for you.
The '128 aluminum heads from a 86L-87 would be better than the 86E heads you have, with portwork and a 3-angle valve job they'll be really good.
Old Aug 22, 2004 | 09:17 PM
lefoy84's Avatar
lefoy84
Thanks, I thought that might be the case.
Old Aug 22, 2004 | 10:09 PM
TA's Avatar
TA
Here's a link with Vic's set-up. His car runs very well
http://forums.corvetteforum.com/member.php?userid=9522
To L98 Perf Upgrade
