Questions regarding temp
I just bought a 1989 Coupe, with what I guess is an L98 with TPI (I know nothing about C4's) and a 6 speed manual, which I guess is a ZF6 speed?
Right off the bat, it had a few problems. It leaked coolant all over the place and oil would blow out of the dipstick hole when I'd get on it, as well as the PCV. I put a new waterpump in it yesterday (what a bitch, had to remove the whole AC bracket.. grrr) so the leak is gone. However it seems like it's still heating up way more then it should be. It gets up from dead cold to around 180 in a matter of just a couple of minutes. Is that normal? I attributed it to all the aluminum, but not sure. Then it gets up to around 220 sitting, and goes as high as ~225 about where the fan comes on and drops it back to ~210. On the freeway it drops down a lot, as low as 170 or a bit lower in some cases, and heats back up when I get out on surface streets. What's considered normal behavior for these cars?
Also, I replaced the PCV and the PCV hose, so I got rid of the oil problem on that side, however it still squirts oil out the dipstick hole if I rev anywhere past ~3000 rpm. I'm going to put a piece of hose over it for now, but I don't know where all that blow-by is coming from. I'm hoping I dont have a bad piston - was going to try some Marvel Mystery oil in allthe holse in case I have some baked on oil? (havn't done a comp check yet, no guage
)so
1) What temps do these usually run at?
2) Why is oil spraying out of my dipstick tunnel at higher RPM's?
I think you can go to a 180 thermo without changing the Prom.
160 is a different story.
But some us us like to keep it cooler with a lower temp thermostat,and fan switch.
another option is to put in a product like Redline wter wetter. There appears to be mixed results out there, but a combination of a 160 deg thermostat, 160 degreee switch, rad fluch and water wetter keeps me in the low 170's on temp. The highest it has gone since is 185 that was this Saturday doing the Woodward Cruise..... 16 miles of bumper to bumper crawling and yet nothing higher than 185.... I was impressed.
The temps are normal-but we call the C4's Hoovers because they suck up anything-thus causing the radiator air flow to be blocked. I suspect that's why you heat up so fast. It's best to remove the radiator schroud and clean-you'll be surprised what you'll find.Alot of us-me included have went to lower temp switches-about $20-25. Let's the fans come on at 200 off at 185. I use a 180 thermo, and there's alot of controvery about using a 160-some people believe a 160 does not allow oil temps to reach a level high enough to purge any contaminants (moisture).
about the PCV causing blow by if it's clogged, but sounds like you already replaced that-so,I have no idea.
) and while I'm there I'll replace the thermostat with the 180 degree one.. I'll let you know how it goes.Meanwhile anyone care to tell me what compression should be?
