B&M Mega-shifter
Old Aug 23, 2004 | 10:06 AM
drjimmy's Avatar
drjimmy
Default B&M Mega-shifter
Has anybody installed a mega shifter in their C4? From what I have seen, it looks like the shifter will need to be modified.
Old Aug 23, 2004 | 03:22 PM
eptaylor's Avatar
eptaylor
If you leave it stock and do not modify the cars' tunnel to lower the shifter, the shifter is rather tall. I installed mine and modified the shifter shaft (shortened & turned it around backwards) and it is about right. I still am going to re-do the shifter shaft to move it forward some more I think. I really like the shifter, works GREAT!
Old Aug 23, 2004 | 09:28 PM
TheCar's Avatar
TheCar
I too am very interested in the megashifter.
did you use the console version for the camaro or the generic fits all version? any info or pics would be great.
Old Aug 23, 2004 | 10:45 PM
eptaylor's Avatar
eptaylor
I used the generic one and did NOT use the rubber boot or the chrome cover, Can take pictures tomorrow afternoon.
Old Aug 24, 2004 | 04:52 PM
TheCar's Avatar
TheCar
Thanks for the info, much appreciated!
Old Aug 24, 2004 | 05:18 PM
Wheelman's Avatar
Wheelman
Whats the point of these?? I don't see how they make an automatic any faster
Old Aug 24, 2004 | 05:21 PM
eptaylor's Avatar
eptaylor
You will NOT miss a shift and it is both faster and surer.
Old Aug 24, 2004 | 06:09 PM
TA's Avatar
TA
If you leave it in "D" you won't miss a shift either
Old Aug 24, 2004 | 06:58 PM
eptaylor's Avatar
eptaylor
[QUOTE=TA]If you leave it in "D" you won't miss a shift either True, but what fun is that?
Old Aug 24, 2004 | 08:00 PM
TA's Avatar
TA
[QUOTE=eptaylor]
If I wanted the fun of shifting, I would have bought a 6 spd. The auto, however, makes a better bracket racer
Old Aug 24, 2004 | 09:53 PM
96BLKTN's Avatar
96BLKTN
Why make it look like a Z28?????
Old Aug 25, 2004 | 07:52 AM
drumboytroy's Avatar
drumboytroy
I installed the "Console Mega Shifter in my 85 this past weekend. This shifter is quite a bit taller than stock. I discarded the metal brackets that come with the shifter. They raise it up even higher. I had to drill another hole in the floor for the new shifter cable almost right below where it connects to the shifter. Under the floor of your car is 2 metal plates that have been riveted to the underside of the fiberglass. This is what your stock shifter is bolted to. I drilled new holes and sat the new shifter directly on the floor and bolted it dowm. Very solid. This shifter has to be in exactly the right place to work right. You will have to cut out a lot of plastic down inside the console.You'll also have to get a relay from radio shack and make a small wiring harness for reverse lights, neutral safety and park switches. I managed to work it out where the shifter plate on top of the console sits just to the very edge of the access flip door for the drink holders. It looks great but was quite a chore. If you have patience and don't mind installing and uninstalling pieces a hundred times to get it right then you shouldn't have a problem. This job is not for the impatient or those who are not somewhat mechanically inclined. It would be very easy to mess up the console top. You gotta have it right before you cut and drill it. I took my time and spent almost 2 days installing mine. It looks factory and works beautifully. I love it. I wish I could post pics on here but I can't. How does a person get permission to post attachments on this forum? I haven't been able to yet. Anyway, it's a decision to ponder. My stock shifter was shot so it was easy to decide. Good luck and holler if I can help. Troy
Old Aug 25, 2004 | 10:11 AM
drjimmy's Avatar
drjimmy
That is why I powdercoated mine black.
Old Aug 25, 2004 | 10:14 AM
drjimmy's Avatar
drjimmy
Good advice but I got what I got. It's either sell what I got ( not going to happen) , convert to 6-speed (to much money) or install ratchet shifter with possible manual valve body from TCI (still looking into valve body swap)
Old Aug 25, 2004 | 10:17 AM
drjimmy's Avatar
drjimmy
The shifter itself wont make it faster but you can shift it at a higher rpm. (you can also do this with the stock shifter)
To B&M Mega-shifter
