LTPWS: should I worry?
Old Aug 23, 2004 | 05:29 PM
Stv50's Avatar
Stv50
Default LTPWS: should I worry?
Last week I took a nice 1 1/2 hour trip in my 96. Stopped for about 2 hours ( Gambling in Oklahoma), then at about 30 minutes into the trip back the LTPWS light came on. I pulled over to make sure all my tires were fine, they were at the right preasure, then statred the car and continued. Afetr a few minutes the light came back on. I guess in about another 10 minutes the light went out and has not come back on since. Over a year ago I had to replace one of the sensors that was broken when I got new tires. But the light coming on has not happened all this time. Just wondering what might have happened and if I need to worry about anything. Thanks in adnance.
Old Aug 23, 2004 | 08:41 PM
kittmaster's Avatar
kittmaster
that happens from time to time, somethings a stray radio signal can cause the system to false. The fact that it turned off means that all the sensors are transmitting correctly. If you really want to know then I'd get the codes from the module by grounding terminals A and B on the ALDL
