Backfiring ... what the devil?
Old Aug 24, 2004 | 11:12 PM
jimbomill's Avatar
jimbomill
Default Backfiring ... what the devil?
My '92 Vert has been sparingly used lately, but still has 141K miles on it. I, like several others last fall, put the Corsa exhaust system on it, so I take it out to give it a good "listen". The last couple of days, I notice in the lower gears, if I let it throttle down, it will backfire, which is something it's not done in the 3 years I've had the car. All my manuals got damaged in the flood that hit us on 12 July. What should I check out first?
Old Aug 25, 2004 | 12:20 AM
bogus's Avatar
bogus
How old is the optispark? that is a sign it is going south bound...
Old Aug 25, 2004 | 06:13 AM
kman0066's Avatar
kman0066
You could also check if you have an exhuast leak, like a loose clamp or the likes.
Old Aug 25, 2004 | 07:54 AM
newbecorvetteguy's Avatar
newbecorvetteguy
If you have the A.I.R. (air injection reaction) system on your car it could be one of the control valves, also known as a diverter valve, or 'gulp' valve. To reduce emissions, air is pumped into the exhaust system. On deceleration, the diverter valves are supposed to close that off. If one of those valves isn't doing it's job you'll get a back fire out the exhaust on deceleration.
Old Aug 25, 2004 | 08:02 AM
runner140*'s Avatar
runner140*
Default Backfire
Take a look at your cat converter and make sure it is clear, also check out your fuel filter. When is the last time you changed it.?
Old Aug 25, 2004 | 10:13 AM
SilverBeast's Avatar
SilverBeast
St. Jude Donor '05
EGR valve can cause that, too. Sounds like it's definitely in that EGR system somewhere.
Old Aug 25, 2004 | 12:28 PM
jimbomill's Avatar
jimbomill
Opti re-done in the last year.
Old Aug 25, 2004 | 12:30 PM
jimbomill's Avatar
jimbomill
Last November had the Corsa exhaust system, I did not do it, so paid too much
Old Aug 25, 2004 | 12:31 PM
jimbomill's Avatar
jimbomill
Sounds like that is what is happening. Know of a good quick check?
Old Aug 25, 2004 | 12:32 PM
jimbomill's Avatar
jimbomill
The CAT could have been affected last November when the new Exhaust was put on... do not know about the Fuel Filter, it's got about 10k miles on it, but almost 3 years.
Old Aug 25, 2004 | 12:33 PM
jimbomill's Avatar
jimbomill
I'm unsure on the maintenence/replacement of the EGR since I had it.
Old Aug 25, 2004 | 11:32 PM
newbecorvetteguy
If you're talking to me about the A.I.R., the way to check is simply disconnect the air hoses going to the exhaust manifolds at the easiest place, start it and give the accelerator a few jabs. If it backfires when hooked up and doesn't when it's not, that's it. Hook up one side, then the other. It should start to backfire when the side with the faulty valve is hooked up.
Old Aug 27, 2004 | 04:58 PM
jimbomill's Avatar
jimbomill
thanks - I'll try it out this weekend!
To Backfiring ... what the devil?
