Tranny Help!!
Old Aug 25, 2004 | 10:31 AM
drpepperkid's Avatar
drpepperkid
Default Tranny Help!!
Hi guys haven't been here in a while but I don't have alot of time so here it is, the stock 700r4 tranny in my '84 is screwed, it doesn't pull in drive or overdrive but it will in first and second, and when its cold the fluid reads almost to the top of that bend in the stick, but as soon as its cranked every drop of fluid is sucked off the stick except for a little that just touches it, I have a B&M deep tranny fluid pan that holds 3 quarts more fluid than the stock one. Is it possible that the seals in the transmission are bad (I know that has nothing to do with it not pulling but it would explain the fluid level) and therefore allowing all of the fluid to run back out of the tranny and into the pan causing it to pull all of the fluid out to refill itself when cranked. In don't know anything about transmissions so I'm just grasping at straws, but any help would be appreciated. Oh yeah, does anyone know if the TCI Street Fighter 700r4 tranny and TCI Saturday Night Special 2,000rpm stall converter will work with my vette, thanks.
Old Aug 25, 2004 | 01:03 PM
brookman's Avatar
brookman
Auto trans fluid should always be check hot and running. If it is not on the stick while running you are low on fluid.
Old Aug 25, 2004 | 01:48 PM
drpepperkid
No offense, but, I know that. I know that there is more than enough fluid in that pan when its cold, its up to almost the top of the bend in the dipstick but when cranked it all gets sucked into the transmission, if it is low on tranny fluid then that would mean for it to be full when warm it would have to be 8 to 10 inches up the stick when its cold because when its cold now its already around four or five inches up the dipstick. When I bought that deep pan I was buying it under the impression that my stock pan was bent and that was the reason the pan continued to leak every time I filled it with fluid hot and running, but when I installed the deep pan it did the same and leaked probably three or four quarts of fluid from the pan, at the time I thought I had overfilled it, because to get it to check full hot and running I had to add almost 11 quarts of fluid, and I didn't drain the entire tranny, I only drained what was in the pan, probably 5 quarts. Anyway after it leaked those three or four quarts it stopped and I drove it and it seemed alright. Now, given everything that has happened I have thought about it and the seals or torque converter or something must be bad to cause all of the fluid in the tranny to drain back into the pan. I don't understand why this would have happened or why the tranny won't pull but it is, and the main thing I want to know is if the TCI Street Fighter 700r4 Tranny that is suppose to work in all applications will work in a 1984 Corvette, because on the Summit website I have found a street fighter tranny that is suppose to be for corvettes specifically and it costs $500 more and I can't afford that right now being a 16 year old boy who only makes $7 an hour for 15 to 20 hours a week. What I'm trying to say is if you guys feel compelled to take up a collection for me so I can get the new tranny it would be fine with me. . But seriously, I really need some help with this so if you know which tranny will work, or you've got a better price from somewhere else please let me know. Thanks.
Old Aug 26, 2004 | 01:51 PM
drpepperkid
PLEASE HELP ME!!!!!!! If someone could tell me of a good tranny that will work with my vette that is reasonbly priced I would really appreciate it. Thanks.
To Tranny Help!!
