Head Volume
Old Aug 26, 2004 | 10:53 AM
lefoy84's Avatar
lefoy84
Default Head Volume
Can anyone tell me what the combustion chamber volume of my 86 cast iron heads is? Will swapping them out to the late 86 aluminum heads help that much? Anyone know who makes the stock pistons and rings.
The engine is sitting on a stand. It has very little wear. I pulled it because it had a massive oil leak from the upper rear of the engine. When I tore it down, I could find no obvious source of the leak.
How much can I raise the compression and still run pump gas? Stock is 9.0 and runs regular OK.
Any help or thoughts is appreciated.
Old Aug 26, 2004 | 11:15 AM
JAKE's Avatar
JAKE
I originally had the same engine, with iron heads too.
I took the heads to a machine shop that does a regular business in race engines - NOT just a normal machine shop that does mostly dealership work.
I had the heads ANGLE milled - NOT flat milled - to the max. I believe .080 was the max that could be cut from mine because of the location of the water jackets.
Angle milling was chosen because it maintained the correct intake manifold alignment, whereas flat milling will call for the intake surfaces to be milled also.
Have the shop cc one chamber before and the same one after the milling and use those numbers to calculate the CR.
I still ran 93 pump gas.
Jake
Old Aug 26, 2004 | 11:19 AM
CFI-EFI's Avatar
CFI-EFI
Can anyone tell me what the combustion chamber volume of my 86 cast iron heads is? .
Nominally, 76ccs.
It should have been obvious and you would have seen it, but the most common source of an oil leak such as you describe is from the intake manifold seal to the block.
The 58cc '86 aluminum heads will get to you around 10.2 to 10.3, depending on your deck height and gasket choice. You should be OK even with the stock cam, due to the aluminum heads.
RACE ON!!!
Old Aug 26, 2004 | 11:23 AM
mos90's Avatar
mos90
Jake
are you saying that if a get a set of heads that are 64 cc and i want to get 56 i can angle mill and not have to do intake work????
Old Aug 26, 2004 | 07:12 PM
lefoy84's Avatar
lefoy84
Is it worth it to swap out the cast iron heads for stock aluminum ones. If I do this what will the compression be with the stock pistons? What kind of performance increase will I see?
Sorry for the questions, but I am trying to learn more about engine tweaking.
Old Aug 26, 2004 | 07:29 PM
CFI-EFI's Avatar
CFI-EFI
RACE ON!!!
Old Aug 26, 2004 | 07:42 PM
lefoy84's Avatar
lefoy84
I apolgize for missing that. What grade of fuel will that require.
To Head Volume
