EGR SES code
Old Sep 1, 2004 | 06:46 PM
VettBrat's Avatar
VettBrat
Default EGR SES code
After I run 7-8 miles at highway speed I get a SES code for the EGR. I am going to pull the top end apart this weekend to check/replace the valve. Is there anything else I should look at besides the valve itself? Would you recommend replacing the pipe, isn't there a control valve or something too, would you replace it all since it is apart? Thanks for any advice for this amateur mechanic.
Old Sep 1, 2004 | 07:53 PM
TA's Avatar
TA
Personally, I would replace all the EGR items, but that being said it may not solve your problem. I also got the dreaded code 32 after highway cruises and I then replaced everything in the EGR system. Guess what........still got the same damn code afterwards. I never got this code until I added a better flowing exhaust system so I'm guessing that its somehow related. I ended up having a custom prom burned that eliminated the code 32.
Old Sep 2, 2004 | 12:57 PM
skybolt31's Avatar
skybolt31
There is a temperature switch in the passagway between the exhaust and the intake and when the EGR is open and gasses are flowing, the switch gets hot and closes. This tells the computer that the EGR is open. If this switch is not closed when it is supposed to be, you get the code. If the switch isn't closed, it could mean that the EGR isn't open for some reason or that the switch is bad. Usually it is a bad switch and the switch is less than $10, so you can do the replace the cheapest part first method and it will probablly work. Or it is easy to trouble shoot, one of the members, 65Z01, I think, has a website that explains exactly how to do it.
To EGR SES code
