Hello if somebody could maybe explain this to me it would help a lot...
First off I have a 1990 so thus I have all this junk....the airpump, hoses, egr, etc etc.....
My question simple....I have seen many people deleting this stuff with that elimination thingy that most of the corvette places are selling.
1. What does all this stuff do?
2. How can we just delete it and not have problems with the car cause of it not being there/why did GM put it on in the first place. (dumb question huh.....why does GM put something useless on our cars! lol)
3. Can you still pass inspection without it? Especially MA and CA inspections....horah horah!
Those components are installed to help improve (reduce) emissions.
From another site:
The Air Pump
The air pump sends (or pumps) compressed air into the exhaust manifold and in some cases to the catalytic converter. The oxygen in the pressurized air helps to burn quite a bit of any unburned hydrocarbons (fuel) and therby converts the poisonous carbon monoxide into good old carbon dioxide.
A belt from the engine drives the air pump. It has little vanes (thin, flat, curved fins) that draw the air into the compression chamber. Here, the air is compressed and sent off to the exhaust manifold where it speeds up the emissions burning process. Stainless steel nozzles are used to shoot the air into the exhaust manifold, because they will not burn.
Some engines use a pulse air injection system. This system uses pulses of exhaust gas to operate an air pump that delivers air into the exhaust system.
MY VETTE COMES WITH ITS OWN LIL SUPERCHARGER ON IT!!!!! LMAO
QUOTE: The air pump sends (or pumps) compressed air into the exhaust manifold and in some cases to the catalytic converter.
WOW and to think if we could only convert this thing...man somebody could patent something hmmmmmmm
I read a web page a few years ago where somebody did in fact, use their air pump to raise the air pressure going into their intake, How much I cant remember but it was enough to cause some detonation.. Claims you could defintely feel a difference but not as much as a production supercharger from what I remember..
...use their air pump to raise the air pressure going into their intake, ...
I find this very hard to believe. I don't think that dinky little pump could provide enough pressure to boost a lawnmower much less a 350. No offense intended but
everybody you gotta keep with me on this one.....say it with me now....
we all have superchargers stock on our corvettes
I mean if all the ricers can get away claiming they get 30 extra horses out of all those stickers they plaster on their cars....surely we can say oh yeh....we got superchargers stock on ours!
lol
too funny this is turning into!
First, you all have underestimated this little pump. I am an engineer and I can tell you that pump does in fact generate pressurized air, not on the same scale as a centrifugal blower or anything, but certainly enough to warrant an attempt at plumbing it into the intake.
Second, you don't have to spend all that money on an AIR pump delete bracket. Do what I did. Take the air pump assembly apart and simply remove the impeller vanes and then re-assemble it. Like a blower, if the vanes are removed there is almost no drag left. Then simply re-install your gutted pump back on the engine. You have to block off the exhaust manifold pipes and the pipe to the cat. Be forewarned, however, you must take your time because the only way to remove them without damaging the rest of the pump is the "break" them in place and then use a pliers to remove them. If you stay patient and take your time, it is very doable. Good Luck
With the vanes in, and fully functioning, the AIR pump draws very little power. The biggest advantage to removing the pump, if you don't care about the air, is to clean up the underhood area and gain easier access for maintance reasons.
