Which Spark Plugs???
Old Sep 2, 2004 | 11:48 PM
McShagger's Avatar
McShagger
Default Which Spark Plugs???
Okay... I know I already asked a few days ago, but no one answered... What kind of spark plugs are best? Best value?
Old Sep 2, 2004 | 11:53 PM
tempest's Avatar
tempest
for best value go with traditional copper plugs. they won't foul as easily as platinums to boot.
IMO the best plugs are clean (and properly gapped) plugs, and brand is more a personal preference.
i've got NGK's, but others have stated they like their AC's & Bosch's (and many others i'm sure).
Old Sep 3, 2004 | 12:02 AM
McShagger's Avatar
McShagger
Temest, that exactly the type of reply I was looking for! I seem to remember nathan plemens saying that he prefered not to use platinum... but I couldnt really remember why... then there are those that say get platinum... I think I will get copper. Im all about keeping running cost down. Things break too often as it is!
Thanks!
Old Sep 3, 2004 | 12:03 AM
rws.1's Avatar
rws.1
my personal preference Bosch Platinum + 4
Platinum gives longer life, the four electrodes are each cut back and ensure a consistent spark
Old Sep 3, 2004 | 09:40 AM
vader86's Avatar
vader86
NGKs if you have LT1/4.
Old Sep 3, 2004 | 09:57 AM
rick lambert's Avatar
rick lambert
AC Delco, there has been several posts about the platinums being junk, along with some of the other more expensive type of plugs.Some have reported pellets coming off. And I've heard from other vette owners their cars even seem to run better with AC's-that's what I run and I'm very satified with them. As far as cut back plugs, I understand it's a waste of time, unless you're running in the 5000 RPM range.
Old Sep 3, 2004 | 10:08 AM
rws.1's Avatar
rws.1
Like almost every replacement or aftermarket part... it's all about personal preference.
I've been using Bosch platinum plugs in all my cars(12) since 1986 with great results (smoother idle, better gas mileage) and no problems. So I stick with them. Others are happy with copper and stick with them.
Old Sep 3, 2004 | 10:11 AM
Corvette0096's Avatar
Corvette0096
I use the NGK FR5's
Old Sep 3, 2004 | 11:11 AM
dynocar's Avatar
dynocar
Would I try to talk anyone out of such plugs, no but I always use standard copper core plugs for my street and race applications. The main reason that manufacturers use exotic metal plugs is because the tips don't wear as fast thus getting them thru their long federally mandated emissions warranty periods. Technically copper is a better conductor of electricity. I have never seen consistant documented scientific proof of better performance of these expensive plugs and I would rather change plugs that eventually get contaminated more often anyway. Unlike many that got sucked into marketing hype such as the SplitFire plugs, I will go just as fast for less.
EJ
Old Sep 3, 2004 | 11:25 AM
byte_me's Avatar
byte_me
I just put Bosch Platinum's in my 94 LT1- as mentioned above- Its a preference as to plug type (just like oil) I have used these plugs on every car I changed plugs on and have never had an issue...they were like $1.50 each....
Its also a good idea to use good wires, and good coil...keep the spark clean and consistant and plugs are plugs! Just my 2 cents!
Cheers...
Old Sep 3, 2004 | 12:04 PM
myblue91's Avatar
myblue91
For mine it's AC Delco plugs,they just work the best
Old Sep 3, 2004 | 12:11 PM
music_man's Avatar
music_man
From: Cicero, IN "Change is inevitable, except from vending machines"
I just put the stock AC's in my 90 Vert and all is well and I saved a bunch over the split fire & plat type plugs. Good luck
Old Sep 3, 2004 | 01:57 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
I've used AutoLite Platinums and NGK Iridiums so far. Have been happy with both.
Old Sep 4, 2004 | 12:53 AM
jzvette's Avatar
jzvette
Go with the mechanics choice, AC Delco are the best. jzvette
To Which Spark Plugs???
