Cleaning an O2 sensor????
Old Sep 3, 2004 | 08:29 PM
vetteman9368's Avatar
vetteman9368
From: I have no tolerence for liberals and fools, but sometimes i repeat myself
CI 3-5-7-8-9 Veteran
St. Jude Donor '08
Default Cleaning an O2 sensor????
Put new sensors in teh car whit the new engine. had an internal vacum leak causing it to run really rich and was also pulling some oil from the lifter valley. i was wondering if it was possible to clean the O2's with some carb cleaner etc. will it damage it?
Old Sep 3, 2004 | 08:34 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Suggest you buy a new 02 sensor, they don't react well to chemicals
seeya
Old Sep 3, 2004 | 08:38 PM
vader86's Avatar
vader86
Dont put any chemicals on that sensor. Dont try to clean it other than just wiping it off.
Old Sep 3, 2004 | 08:43 PM
vetteman9368
St. Jude Donor '08
seeya
well screw it there's $100 i'm not gonna spend
Old Sep 3, 2004 | 08:51 PM
TheStef's Avatar
TheStef
Why not use brake cleaner, ABS safe/sensor safe?
Old Sep 3, 2004 | 09:21 PM
lead foot 85 vet's Avatar
lead foot 85 vet
I've heard of guys using a torch to burn lead from race gas off after racing........might work to clean oil, but then again the exhaust gas temp should do that.
Old Sep 3, 2004 | 10:33 PM
saigon68's Avatar
saigon68
THE TORCH WILL WORK. I USED A SLIGHTLY OXYDIZING FLAME.
REMEMBER, WE'RE CLEANING, NOT COOKING.
Old Sep 4, 2004 | 02:01 AM
comp's Avatar
comp
also have got them to run lean (no load) to help clean
To Cleaning an O2 sensor????
