TV Cable Delete????
Old Sep 3, 2004 | 11:15 PM
bigjack's Avatar
bigjack
Default TV Cable Delete????
Can the TV cable on a man. trans. "85 be deleted without any adverse effect(s)? Thanks, Jack
Old Sep 3, 2004 | 11:19 PM
flyersfan1088's Avatar
flyersfan1088
From: What did the 5 fingers say to the face? SLAP!!
The factory did you a favor and deleted it for you. Manual transmissions don't have TV cables
Old Sep 3, 2004 | 11:30 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
An A4 uses the TV cable to control line pressure for part throttle shift points. The other two cables are throttle and cruise.
If your 4+3 has three cables the third may have something to do with the OD, but is not a TV cable.
Old Sep 4, 2004 | 12:02 AM
scorp508's Avatar
scorp508
Jim, the '84 and '85 4+3 vehicles do have a TV cable. It goes directly to the overdrive unit for the kickdown effect. The later 86-88 units went to full electronic control.
If you remove that cable you'll no longer get the overdrive kickdowns.
To TV Cable Delete????
