L98 combustion chamber?
Sep 4, 2004 | 11:21 PM
how many Cc is it?
Sep 4, 2004 | 11:31 PM
For a 90, it should be 58cc
Sep 4, 2004 | 11:49 PM
Quote:
thanks
Sep 4, 2004 | 11:55 PM
is it like a 305 ??? or is it like a Vortec chamber?????
Sep 5, 2004 | 01:27 PM
no clue heads rnt off yet. they r the stock l98 alumn. heads.
Sep 5, 2004 | 01:58 PM
Iron heads: 76 ccs
Aluminum heads: 58 ccs.
Sep 5, 2004 | 03:32 PM
TY. now does any1 know a set of pistons tht r forged tht will drop my Cr to 8.5:1 and the motor is goin to be be .030 overbore adn decked .010 and heads resurfaced.
Sep 5, 2004 | 06:17 PM
Stock 1984-85 pistons are forged and produce 9:1 compression with the cast iron heads. If you forgo the block decking and only surface cut the heads to be sure they're straight, you'll be close. Other then that, you are going to have to assemble a pile of catalogs, along with YOUR engines specs, and figure it for yourself.
RACE ON!!!
Sep 5, 2004 | 07:37 PM
well fi they produce a 9.1:1 with 76cch eads, then its goin to be higher than 9.1:1 with 58cc heads....
Sep 5, 2004 | 08:57 PM
