Help!!! Dies at will
It will be running just fine, then goes to actinig as if it's running on 6 cylinders, then dies. It usually will start back up~only to die again soon, but when it gets warmed up it dies sooner until eventually it won't start at all until the engine cools a bit (and it's not overheating either).
Please help!! It left me stranded at Sears Point during a race and I can't have that happen. I'm done racing until I fix it
Then check for a prime at the fuel rail after you turn the key on.
Then check for spark while cranking; a timing light will serve here.
Also, pull any stored codes.
Check your Catalytic converter for being plugged. Also, check your fuel pump relay. Its on the firewall, drivers side, next to the winsshield wiper motor. remove the 2 nuts and pull the relay off. Check the wires and plugs on the bottom of it for corrosion, looseness, and cuts.
My car ran bad, and would stal lat anywhere near idle, ended up being plugged cat, and corroded Fuel pump realy wires.
90 model has precats. If one or both have goen bad, theyu could have plugged up the main cat.
Good luck.
Are these things that would normally be detected with diagnostics? I took it to a Chevy dealership and then to a buddy of mine that is very Corvette savy (races/owns 'Vettes) who owns a transmission shop and nobody could figure it out *yet*.
Thanks.
TIA!
Again, what's the PCM? Where is it and how much $$$ to replace???
I'm sorry if this is a silly question, but I don't know.
Most of the Vettes folks refer to it as the ECM Electronic Control Module. It's the computer.
As far as where it's located, it varies with the year of the car. Some, like my 86 have them mounted under the dash on the passenger side behind what we refer to as the "bread-box"; later models have them mounted in the engine compartment. GM loves to change things.
Hope this helps.
Jake
Most problems that seem to be fuel are, in fact, ignition, so that's where I'd look first. I would advise against throwing parts at the problem in the HOPE of correcting it. I'm a firm believer in diagnosing the cause then, if necessary, buy what parts are needed.
I not sure which ignition system your car has, whether it's Opti-Spark or HEI. If yours has a regular HEI distributor, I'd pull the module (under the distributor cap) and have it checked at one of the local auto parts stores. AutoZone and O'Reilly's (if there's one in your area) will check the module for free.
Some folks may tell you that the module is an "either/or" situation; either it worked OR it doesn't, but that's wrong. The module can be effected by heat/virbation and will work intermittently at times.
If you have the Opti setup, you'll have to seek help from the guys that are familiar with that system. I've never fooled with Opti.
You can mount a fuel pressure gauge and monitor it to see if the pressure drops just before the engine dies.
You can also run 12V directly to the ALDL to power the fuel pump which should bypass the relay and oil pressure switch pump circuitry. If the engine continues to run, then the fuel pump relay may be bad. I've never had to do that particular trouble-shooting procedure, but It's listed in my service manual for the 86. If you need me to post it, I'll look it up and post it.
It would be a good idea for you guys to buy a Chilton book that has the trouble-shooting procedures for all sorts of problems that you'll probably run into at one time or another.
Keep us posted.
Jake
I'll keep you posted!
If all those check out, you can pick up a ScanTool at one of your local auto parts stores, like AutoZone, and plug it right in to the car's computer to read out all the sensor readings as the engine is running.
Remember, it's all about the numbers. All the sensors have a range within which they should operate when functioning properly. This range is expressed numerically. For example, the 02 sensor gives a mV reading of from about 35 mV to 900 mV or so when working properly and the readings should quickly cycle from low to high and back to low, etc. If it doesn't or is sluggish, then you'll know the oxygen sensor/wiring circuit needs attention.
When you plug into the car's computer with the ScanTool you can read the numbers for the sensors and can then tell if one or more of the sensors is operating out of its designed range.
Intermittent problems - those that don't cause a hard SES code to be stored - can be a bear to track down. Problems with the ignition module, fuel pump, coil, pick-up coil, rotor, bad ground connection, etc., are things that probably won't cause a code to be set. There are many others, too.
If you keep us posted on what progress you're making, I'll post the trouble-shooting procedures you may need to help sort this out.
Jake
