Tires for drag racing
Any suggestions??
Patti - IL
Then think about Drag radials if you will be driving to the track.
Sizes and rims are variable depending on what you have and where you decide you want to be.
Arrive at the strip with about 1/3-1/2 tank of fuel, drop rear tire pressure to around 30psi, drive around the water box and do a little dry hop to clean the tires before staging.
BTW, how do you like those GY Eagles? I'll soon be needing tires and they are one of my choices. Have you ever driven with them in light snow? Also please let us know how hook at the strip.
If you realy like drag racing and need a little more grip I recommend a set of BFG DRs. Last Sat. I bolted up a set of 255/16s from the IROC onto the Vette, lowered inflation to 17psi and hookup was great.
