M&H drag radials
Old Sep 7, 2004 | 11:34 AM
GiDvEtTe84's Avatar
GiDvEtTe84
Default M&H drag radials
Anyone know if they make some tubeless drag radials for 16" wheels? I was thinking of getting some next time around. Also how wide can you go on a 9.5" wide wheel? Any other suggestions would be appreciated as well. Thanks.
Old Sep 7, 2004 | 11:52 AM
CFI-EFI's Avatar
CFI-EFI
Your thread title says, "M&H", but the question reads like it may apply to all DRs. If you specifically want M&H, check with Summit or Jegs. BFG Drag Radials are tubeless. In 16" they only make the P255/50. I have them on both 8.5" and 9.5" stock wheels.
RACE ON!!!
Old Sep 7, 2004 | 12:02 PM
GiDvEtTe84's Avatar
GiDvEtTe84
I have heard that the M&Hs do well in the rain. Its usually wet here in LA. I did want something a little wider than stock tho. Hope i dont have to go to some 15's to do it.
Old Sep 7, 2004 | 07:27 PM
CFI-EFI's Avatar
CFI-EFI
If hydroplaning is your concern, you want narrower, not wider. That's why C4s have the problems they do...even stock.
RACE ON!!!
Old Sep 8, 2004 | 05:10 PM
GiDvEtTe84's Avatar
GiDvEtTe84
Its not hydroplaning, its traction im worried about. The tread pattern in other words. I should have a truck to drive in the rain by then. Thanks.
To M&H drag radials
