Those who have restored the solid top....
Old Sep 7, 2004 | 12:47 PM
Wheelman's Avatar
Wheelman
Default Those who have restored the solid top....
What did you use to glue the new headliner material to the backer board??
Old Sep 7, 2004 | 12:55 PM
MrRenoman's Avatar
MrRenoman
3M makes some spray adhesive you can get at any parts supply, but I have not had much luck with it. It fails over time. I actually took mine to an upholsterer and had it done for $25. The headliner and pad is held on with velcro, I think. I think you can remove the fabric from the pad very carefully, then the pad can be removed. It's been awhile but that's what I vaguely remember. I had it done years ago and haven't had a problem with it since. The adhesive that upholsterer's use is very good. Might not be worth messing with but that's only my opinion.
Art
Old Sep 8, 2004 | 11:56 AM
Wheelman's Avatar
Wheelman
Anybody have an idea where I can get the right kind of glue for this??? If not, I will just bring the headliner material to the upholstery store
Old Sep 8, 2004 | 05:22 PM
MPforUSMC's Avatar
MPforUSMC
I just bout some heavy duty adhesive spray and generously sprayed it onto the the foam piece and started from one corner working my way down. Its held up for 6 months with no sign of sagging.
To Those who have restored the solid top....
