Help with L98 plenum runners
Old Sep 8, 2004 | 10:11 AM
CREWZIN's Avatar
CREWZIN
Default Help with L98 plenum runners
Help! I'm in the middle of taking off the valve covers, plenum and runners (down tubes) to have them powder coated. Got the plenum off and the runners sticking up in the air. Got all five Hex bolts out of the bottom of the runners and the darn things won't move. I've pounded on them with rubber mallet and they seem stuck like they are glued on. Any help appreciated.
Old Sep 8, 2004 | 10:30 AM
Wheelman's Avatar
Wheelman
There are 2 bolts that go in the opposite direction inside the runners. The one for the passenger side is behind the egr switch on the front of the manifold and the one for the drivers side is back behind the egr valve in front of the distributor
Old Sep 8, 2004 | 10:32 AM
Wheelman's Avatar
Wheelman
Also if you've never taken them off before there are 2 longer bolts on each side down at the very bottom of the runners behind the fuel injector wiring harness.
Old Sep 8, 2004 | 11:24 AM
CREWZIN's Avatar
CREWZIN
Wheelman,
Beautiful...found them and the back one came out without too much trouble, BUT how the heck can I get around that wiring harness contraption that's fitted on the maniflod right behind the TB? It's about 1 inch away from that front bolt and it doesn't seem to want to come out and stopping me from getting to that inside Hex bolt. Thanks.
Old Sep 8, 2004 | 11:43 AM
Wheelman's Avatar
Wheelman
There are two (10mm i think) nuts that hold that harness to the lower intake manifold between the runners. If you unplug the injectors and pull the wires out of the way you can get to the lower runner bolts easier.
Old Sep 8, 2004 | 12:04 PM
Trog's Avatar
Trog
That front area on mine is the EGR control box & its bracket is bolted down under the rear thermo. housing bolt... Remove that bolt & the whole thing can be moved out of the way.
Old Sep 8, 2004 | 12:12 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
You will need to disconnect the cold start injector from the fuel rail to remove the left side runner. If it won't stop oozing fuel, disconnect the fuel lines at the right front of the fuel rail and loop a piece of rubber tubing between them, with hose clamps on it.
Old Sep 8, 2004 | 12:58 PM
CREWZIN's Avatar
CREWZIN
Wheelman = Thanks.
Trog = I saw that but I jury-rigged a small T-40 Torx head and very small open end wrench and was able to back out the bolt without undoing the thermostat bolt.
Plenum is off. Passenger side valve cover and runner is off.
Drivers side. 65Z01 = before I can even get to the runner, I take off the valve cover. Guess what...it's hitting on the bolt that goes through the air pump (I think) that's right above the alternator. Bolt head is 1/2 inch from pulley...looks like that all has to come apart to back the bolt out.
Old Sep 8, 2004 | 01:39 PM
65Z01's Avatar
65Z01
On my '88 I had to move the alt & AIR pump brackets forward about 1/4" to remove the left valve cover; the A/C compressor and AIR diverter brackets had to be moved forward and the EGR tube removed to remove the right side valve cover.
It realy isn't so bad, just a little tedious.
Old Sep 8, 2004 | 03:45 PM
CREWZIN's Avatar
CREWZIN
WOW...I did it! Only somebody up above knows if I'll ever get the thing back together again. I've got nuts and bolts and tubes all over the place marked with little notes and diagrams to tell me where most of them go back together. It hardly leaked any gas from the cold injector and I used a drummel to take the 1/4 inch of thread off the air pump bolt so the valve cover would come off.
Thanks for all the help guys. I might need some more to help put the thing back together when it comes back from the powder coating shop. They are doing the plenum, both runners and both valve covers with a bright silver plus clear coating it. I also have a small dent in one of the runners which they will fill in before coating it. $200.00
To Help with L98 plenum runners
