How about this cam
Old Sep 8, 2004 | 02:43 PM
MR.KIDD's Avatar
MR.KIDD
Default How about this cam
I am doing a long rod 406 with 195 afr heads and miniram in a 85 have any of you ever used this cam suggested by Compscam HR230/236 560/570 lsa114 I would be using 1.6 rockers with it,if so how well did it perform and how does it sound.
Old Sep 8, 2004 | 07:24 PM
redfast's Avatar
redfast
I have sort of the same combo as you on a roller block. I used the tpis zz9x roller cam. Don't know about the cam your talking about? It may be too great of a lift with the 1.6 rr. AFR has a valve float kit for 6K+ rpm's.
Old Sep 8, 2004 | 08:10 PM
chriswtx's Avatar
chriswtx
That cam should be fine with your combo...Make lots of HP.. Its a little smaller than the one I am using on my 380ci
Old Sep 8, 2004 | 11:20 PM
MPM IV's Avatar
MPM IV
I have a comp cam 306 in a 396 and I'm in the process of going bigger. In a 406 I would run the GM 847 cam at a minimum, or a custom grind. Good luck.
Old Sep 9, 2004 | 11:06 AM
MR.KIDD's Avatar
MR.KIDD
What cam are you using.
Old Sep 9, 2004 | 11:09 AM
MR.KIDD's Avatar
MR.KIDD
What are the specs on the GM 847?
Old Sep 9, 2004 | 07:56 PM
chriswtx's Avatar
chriswtx
I'm using CompCam's street solid roller #12-702-8. It has 236/236@.50 and .550 lift with 1.5 rockers.
Old Sep 10, 2004 | 04:11 AM
88421VETTE's Avatar
88421VETTE
man the cam in my 406 is tiny I'm running a comp XE 274
Old Sep 10, 2004 | 12:16 PM
MR.KIDD's Avatar
MR.KIDD
How much vaccum does it make and what is the lsa and lash ajustment.THANKS
Old Sep 10, 2004 | 12:52 PM
MPM IV's Avatar
MPM IV
Specs for the 847 are 234/242* .575/.595 lsa112 with 1.6 rockers.
Old Sep 10, 2004 | 08:40 PM
chriswtx's Avatar
chriswtx
Valve lash is .20, not sure on the vaccum, I should know this weekend.
LSA.angle 110* and intake centerline 106*
Old Sep 11, 2004 | 07:47 PM
Rays Vet's Avatar
Rays Vet
Now thats what I call a cam!!!! Hope you get it before June and congradulations on cam choice and you know what
To How about this cam
