Race Motor: Desktop Dyno Please?
Old Sep 9, 2004 | 04:51 AM
DREGSZ's Avatar
DREGSZ
Default Race Motor: Desktop Dyno Please?
Hi All,
Could someone please plug this into the desktop dyno and give me some HP and Tq numbers please.
GM 400ci Block w forged 350 (3.48") crank,, (376CI) 6.2 rods and 12:1 pistons, .020 over,
Crower solid roller cam PN 00430,
105=256/260@ 50 adv 284/294
626/626 gross lift w with 1.5 rockers, (I'm running 1.6 rockers on the exhaust, but I don't know what that raises the exhaust lift to.
Pro action, Pro lightning Aluminum heads w 200 cc runners and 66 CC CNC,chambers
Is any more info needed?
Evan
Old Sep 9, 2004 | 09:37 AM
ralph's Avatar
ralph
what do the heads flow
what are you using for an intake and exhaust
is this a purpose built race engine
Old Sep 9, 2004 | 04:14 PM
DREGSZ's Avatar
DREGSZ
Heads, 200 cc runner, 66 cc chambers
Intake Port Test Data @28" of water
.100 .200 .300 .400 .500 .600 .700
70.74 146.41 203.72 249.84 260.51 268.51 276.41
Exhaust Port Test Data @28" of water
56.90 100.99 156.94 176.85 186.34 190.13 194.87
Wieand Team G single plane manifold, 2500-7000 rpm
Exhaust, 175" primary to 3" collector, long tube Howe custom Headers
Evan
Old Sep 9, 2004 | 05:04 PM
JAKE's Avatar
JAKE
Originally Posted by Evan Ginsberg
Hi All,
GM 400ci Block w forged 350 (3.48") crank,, (376CI) 6.2 rods and 12:1 pistons, .020 over, Thanks Evan
6.2 Rods??
Jake
Old Sep 9, 2004 | 11:25 PM
DukeDiablo's Avatar
DukeDiablo
Evan-
Click below and try the eval version:
Desktop Dyno 2000
Old Sep 10, 2004 | 01:22 AM
DREGSZ's Avatar
DREGSZ
THanks for the link, the program doesn't want to run on my puter,
Yes, Eagle forged 6.2" 3d, H Beam rods, Eagle forged crank and JE pistons
Old Sep 10, 2004 | 01:32 AM
DukeDiablo's Avatar
DukeDiablo
What are your system specs...maybe I can help?
It's a self extracting archive...you have to install it first. Just click through the self extracter and then you can find the program on your C: drive and run it.
Unless you are running Windows 3.11 or 95???
Old Sep 10, 2004 | 01:43 AM
DukeDiablo's Avatar
DukeDiablo
Ok, I'm setting everything up for a run.
What are the sizes of your intake and exhaust valves?
What kind of CFM induction do you think you have?
To Race Motor: Desktop Dyno Please?
