Thought I would start a new thread since the last discussion about this product had many replies.
Just ordered the hurst billet shifter (391-7084) and the hurst **** to go with it. I downloaded the install instruction sheets from Mr Gasket site.
My question is: If I follow the instructions are there any other problems that may come up during the install?
Those instructions are pretty good. But, there are always problems that can come up!!! It was a long, tedious job.....but not to bad! Well worth the effort though.
I don't remember if the instructions say to drop the exhaust but it is a good idea to do so. There are those that say it is not necessary but for the 20 minutes it takes, it makes it a hellova lot easier to access the shifter from underneath.
Get yourself a long punch, getting the pin out is a chore, putting it back in is even worse!
The lower rubber boot is the biggest pain, it wants to get in your way. Once you cut the tie wraps, take a metal coat hanger, bend it into a hook and wrap that end in tape to avoid tearing the rubber. Hook the rubber boot and using the hanger, pull it back and hook the other end of the hanger around something to help keep it out of your way.
Also, have some 220 grit sand paper on hand to take some of the powder coating off at the pivot point. The shifter is machined very close and the powder coating makes it stick. Oh, and straight from Chris Reinhardt's mouth: Don't use the lube provided, get some white lithium grease and use it.
BTW, Chris is the designer of that shifter. Great guy!
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
This is excellent advise. The boot getting in the way is the worst part. Other than that it is pretty easy.
When I installed mine, the upper boot was hard to re install just because it was hard to get at. I also had to replace the lower boot as mine was ripped from the previous owner's mechanic. I also had my trusty Helms Service Manual for reference. This is the most enjoyable mod I've done to my Vette. Enjoy the results.
This would also be a good time to swap out your fuel filter.
Just received the billet shifter kit and I was wondering if anyone knew how much shorter the new stick is compared to the stock?
Search the forums, that info is posted someplace.
Going from memory, the **** ends up just over an inch lower. The shift throw (how far you move you hand to shift) is shortened by 30%, not the lever.
The lever is actually longer below the pivot point and that is what does most of the 30% improvement.
A real nice feature is that the new lever eliminates th erubber in the stock lever so you get a better feel of what is going on.
When you have both levers out and side by side, take a good look at them. The factory lever is actually more expensive to build. Chevy could have given us Hurst shifter performance right out of the facctory and shaved ~37 cents of the cost of building the lever at the same time.
