Ing Timing part 2
Old Sep 10, 2004 | 10:04 PM
toyvet1's Avatar
toyvet1
Default Ing Timing part 2
Checked the engine timing today. Using mt Auto X-ray, when cruising at 70 mph /3500 rpm/ 13% throttle angle I have 44.8 advance. I go wot and timing goes to 22 degrees advance. This sound backward to me. does it sound right to you?
Old Sep 10, 2004 | 10:17 PM
JAKE's Avatar
JAKE
Yes that's right, I mean it's not backwards. Your 44 degrees of timing during cruise conditions is for best fuel economy and lowest emissions but is too much for best WOT power production - in most cases anyway.
I can't attest to the actual 22 degrees being the best for your setup (seems low to me) but when you nail the throttle and go WOT, the system enters PE (Power Enrichment) mode which uses different timing and fuel tables and ignores 02 feed-back.
Mine system goes to the 36 degree range when I go WOT. At closed loop idle I'm showing 22 degrees.
I can only speculate that there may be some knock that is causing the ECM to retard the timing below what it should be for optimum power output.
How does the engine pull with 22 degrees?
Jake
Old Sep 10, 2004 | 10:20 PM
JAKE's Avatar
JAKE
Another thought I just had: I'm not familiar with how Auto-XRay displays ignition timing, but it may only be showing the timing that the ECM is commanding and NOT including the initial timing.
If that's the case, you'd have to add the base/initial timing to the 22 degrees to give you the total timing.
Jake
Old Sep 10, 2004 | 10:42 PM
toyvet1's Avatar
toyvet1
Knock sensor reading is 2(?) and it shows 0* retard. Car pulls ok but is lacking low end torque but don't think timing is a issue for it.
Old Sep 11, 2004 | 12:37 PM
JAKE's Avatar
JAKE
How'd you come to that conclusion?
Low ignition timing will DEFINITELY effect low end torque. As I said, mine (and most others from the posts I've read) have 22 degrees at idle and low to mid 30s at WOT.
Jake
Old Sep 11, 2004 | 02:24 PM
toyvet1's Avatar
toyvet1
maybe lack of knowledge. Thats why I am getting more and more knowledge from this forum.
6* at idle with wire unplugged. I don't know what it is with wire plugged its off the scale. But 22-24 at wot would be 28-30 if you add the six initial.
Maybe I'll bump up initial a little to see what happens..
Old Sep 11, 2004 | 07:31 PM
Rays Vet's Avatar
Rays Vet
If you could see the programming (chip) it would be much clearer.22 is low and may be due to some initial spark knock and recovery is slow or never happened. 28 to 30ish is about normal from what I've seen in the timing charts for these cars.Cannot remember what the spark adders contributed.
Old Sep 13, 2004 | 03:06 PM
JAKE's Avatar
JAKE
Yes, that's normal.
With the EST wire CONNECTED, the timing mark WILL be off the scale because the ECM is adding a certain amount of timing to the base timing you set with the timing light.
Jake
Old Sep 13, 2004 | 03:31 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
If you have an '85-'89 L98 check the TPS base voltage (at 450rpm) and WOT voltage. If you bump the base setting from the stock .54Vdc to about .65Vdc you will get a little more fuel and spark advance for crisper throttle response.
Then try bumping base timing to 8-10deg BTDC. If your scanner shows any knock retard at WOT, back off a degree or two.
To Ing Timing part 2
