'88 fuel tank sender problem?
I Have An 88 Vette. In The Past Month Or So, When The My Gas Guage Indicated That I Had About A 1/4 Tank Of Gas, The Engine Wanted To Cut Out As If I Was Running Out Of Gas.
Yesterday, I Had Almost A Full Tank Of Gas And Stopped To "top It Off" For Hurricane Francis. As I Drove Away, I Noticed That My Led Guage Was Reading About Half A Tank When I Started With Almost A Full Tank When I Gassed Up!.
I Noticed The Guage/bar Graph Creep Up To The Full Mark In About A Min Or So Of Driving. So, Do Ya Think It Is The Pump - Float - Sensor Unit?........thanks!
YA MEAN THERE IS AN OPEN SET OF CONTACTS EXPOSED IN THE GASOLINE IN THE TANK?????....ISN'T THAT AN EXPLOSION WAITING TO HAPPEN?.....AT ANY RATE, I WILL GIVE IT A SHOT AS MY BROKEN HAND IS DOING A BIT BETTER. IS THAT THE SENDER UNIT OR IS THAT A SEPARATE ENTITY?.....THANKS AGAIN!
PS, ON A SEPARATE NOTE, WOULD I GET A CODE IF I HAD A PROBLEM WITH MY OXYGEN SENSOR? WOULD THE CAR RUN W/O GETTING A CODE BUT, WITH LOUSY PICK-UP FROM A STANDING START?
