Engine builders-Bent crank, replace or rebuild?
Old Sep 12, 2004 | 05:35 PM
cyclerage23's Avatar
cyclerage23
Default Engine builders-Bent crank, replace or rebuild?
The crank in our 406 project is bent. The motor about 3k miles on it. Can we just install a new crank and bearings or do we have to take everything apart and have it balanced again? Thank for the help.
Jason
Old Sep 12, 2004 | 05:39 PM
CFI-EFI's Avatar
CFI-EFI
It will have to be rebalanced to the weights of YOUR components.
RACE ON!!!
Old Sep 12, 2004 | 05:57 PM
cyclerage23
RACE ON!!!
So can I jut pull 1 piston/rod an send it to the machine shop or do I have to pull the whole thing apart?
thanks alot,
Jason
Old Sep 12, 2004 | 06:13 PM
bogus's Avatar
bogus
thanks alot,
Jason
I know this is a pain in the ***, but I would seriously consider re-rebuilding the entire motor.
If you have a bent crank, what else was hurt?
Old Sep 12, 2004 | 06:52 PM
cyclerage23
I dont think anything else is bad. The engine (ski_down_it old motor)already has Lunati rods/Wiesco pistons(stock crank). It still runs but you can see the end of it is not spinning true. It keeps throwing belts and breaking the accessories.
Old Sep 12, 2004 | 07:20 PM
Upstate's Avatar
Upstate
From: [Quote=WOEII] Is dried brown doodie powders man! [/Quote]
I am thinking along the same lines as Bogus. At the very least I would perform a complete disassembly and inspect every piston, the rods for straightness, both ends of the rods for out of round, and the piston pins. You have to ask yourself if you really want to do this twice because you know you'll be kicking yourself later in the event another part of the reciprocating assembly fails and you have to take it apart again.
Just my .02
Old Sep 12, 2004 | 07:32 PM
rick lambert's Avatar
rick lambert
I've never heard of a bent crank before. But, if indeed it's bent, then I would worry about rods and pistons. Best to have the whole bottom end looked at.
Old Sep 12, 2004 | 07:54 PM
SloRvette's Avatar
SloRvette
Cruise-In VII Veteran
Have you taken the bottom end apart to be sure that it's the crank and not some issue with the balancer or your pulley's ?
If the crank is bent, I'd be looking to have the block magnafluxed to make sure nothing has cracked. I'd then be looking to try to see if the damage is shipping related or run related. If it's run related, it's time to give everything a real close once over.
You'll need to give the machine shop your balancer, flex plate / flywheel, upper and lower rod bearing halfs, rings, piston, and pin for a single cylinder for them to come up with a bob weight to balance the new crank. It wouldn't hurt to double check the weights of all the pistons and rods.
Old Sep 12, 2004 | 10:54 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I would think that align boring or at least checking would be in order too, if it is truly bent.
Old Sep 13, 2004 | 12:07 AM
chriswtx's Avatar
chriswtx
with SloRvette, make sure its not the balancer or pulley that is bent. It takes alot to bend a steel crank. It usually takes NOS, a supercharger backfire or somthing like a broken rod through the side of the block. My crank is a forged Callies that I bought from a friend of mine out of his dragster. He had aluminium rods and one broke. And it put a hole the size of a grape fruit through the side of the block. But the crank is still straight as an arrow....
Old Sep 13, 2004 | 07:45 AM
cyclerage23
Default crank
I wish it was a Callies! This crank is a stock GM cast crank. A few people told me this would happen and not to even run the motor with the stock crank but........oh well. The balancer/pulley are gone. Along with the woodruf key. When the engine is started, you can see the end of the crank is swinging about 1/8" from side to side. I thought at first that it may have been a main bearing but wont know untill this thing comes apart.
Old Sep 13, 2004 | 08:08 AM
rick lambert
1/8th seems like that thing would be knocking like he77! plus I'd also think you'd be spewing oil all over from the front of the engine. The stock cranks from GM have been taking alot of punishment over the years and typically hold up very well. Sorry about your problem-but please let us know-at least I'm very curious to the outcome.
Old Sep 13, 2004 | 12:15 PM
cyclerage23
I'm guessing the bend would be about 1/16 in direction, but would go both ways when spinning. Thanks for all the help!
Old Sep 13, 2004 | 01:31 PM
JAKE's Avatar
JAKE
It it was my engine, I'd pull it for a complete exam and rebuild.
Jake
Old Sep 13, 2004 | 02:04 PM
ir0nmaiden420's Avatar
ir0nmaiden420
From: Sarcasm. Just one of the many services I offer.
I got a bent crank one time. GF was on top and leaned back too far...oh well I guess thats a story for another time
Old Sep 13, 2004 | 02:17 PM
SloRvette's Avatar
SloRvette
Have you really run the motor since you bought it, or is this damage that was there that you're just figuring out now ?
Old Sep 14, 2004 | 09:50 PM
cyclerage23
I believe this has happened since we installed it, but the bend could have been there and has now gotting worse. Who knows at this point.
To Engine builders-Bent crank, replace or rebuild?
