Timing help
I've already tried 110 race gas in 20 % proportion with 80 % of 91 gas giving me around a 95 octane rating and it still knocks and pulls 7 degrees of timing. It smells really good too.
It also knocks and pulls timing with no load in neutral.
I am not sure if it's false or real cuz the car feels like it's under a load when it isn't. It feels like I'm always fighting something.
Is there a chance that the timing indicator could be off and what the mechanic thought was 6 degrees was not actually 6 degrees?
What would the symptoms be of timing being off? I also experience hard starting, is that a symptom?
I'm gonna try 4 degrees, do a scan run, then 2 degrees and another scan run to see if it eliminates knock. It's really frustrating!
I've already upgraded the knock sensor last year to a less sensitive one. I read about the knock sensor should only be tightened to 15 #'s and no more. I told my mechanic and he said "That doesn't sound like much, it'll probably fall out if it's only 15 #" which leads me to believe it's in there tight.
The car shows very few knock counts under normal conditions, but at WOT, it knocks and pulls 7 degrees verified by DataMaster.
It sounds like one thing you are going to have to do, is verify your timing marks. There seems to be enough doubt in your mind, at this point, that further diagnosis would be a waste of time, if you can't have faith in your readings. Remember, "GICO". Garbage in garbage out.
What do you mean, exactly, by "hard starts". If it cranks more slowly, or cranks slow and then fast, when hot, only, THAT is a symptom of too much initial advance.
RACE ON!!!
[b] It's really frustrating!
On a new build, I always verify the damper TDC mark using the positive stop method and verify the timing tab using a degree wheel.
You can try to verify the marks using a dial-back timing light if you use a good, accurate one.
Jake
Jake
RACE ON!!!
Again, just a guess........
Yes thats how they work...sort of...
You use the timing light to dial in your advance. To see what you have you turn the dial while looking at the dampner marks. When the dampner marks line up with Top Dead Center(0*) then where you stop turning the dial is the timming that the engine is set at. The other way is to, say you are looking for 6* advanced. Then you would set the dail on the timing light at 6* advanced. Using the timing light and watching the dampner marks turn the distributor until the TDC(0*) marks line up. Then you are set at 6* advanced.
Can you please explain verifying the timing marks with a dial back timing light?
RACE ON!!!
Jake
Jake
Not really. At least not in a way *I* understand. I know how a dial back timing light works. I have one and use it all the time. What I DON'T understand, is how to use it to verify the accuracy of the timing marks.
RACE ON!!!
RACE ON!!!
It works the other way too. If you turn the **** to the 6 degree mark, you'd then turn the distributor until the balancer mark is at Zero on the tab. Then when you turn the **** back to Zero, the mark on the balancer should align with 6 degrees on the tab.
If they don't agree, then either the mark on the balancer or the tab is off.
Some SB Chevy balancers have the TDC mark off-set and the result is NOT an indication of the #1 piston being at TDC. I forgot exactly how many degrees the mark was off-set, but IT IS substantial.
That's why I always verify the balancer TDC mark with the #1 piston using the positive stop method. In fact, many after-market balancers don't have TDC marked at all and it's up to the installer to find and mark the balancer to indicate TRUE TDC.
Oh, I guess it's possible for the timing light itself to be off, that's why I recommended getting a quality light. Even if it is "off" I suspect it wouldn't be enough to work up a sweat over.
But as I've said before, I don't get locked in on 'numbers'; I let the engine tell me what it wants/likes. Dyno tuning works the same way; you'd tweak the base settings of fuel, timing, plug gap, valve lash, etc., until you get the best results and let the actual 'numbers' fall where they may.
The 'numbers' can be used, however, as a barometer. If any of the numbers are DRASTICALLY different from numbers known to work well on other similar engines, I'd start having a look-see elsewhere for the cause.
Also balancers and timing tabs are a mated pair; mated for life (not like so many marriages these days). So if the tab and/or balancer are changed to ones that are not the same as the ones they're replacing, the readings will be off as a result. That is, UNLESS the new balancer and tab as also a mated pair.
If the balancer is not the exact same diameter AND/OR it doesn't have the TDC mark in the exact same location OR if the timing tab has it's TDC location in a slightly different location OR if the tab has it's numbers spaced closer or farther away from each other than the one it's replacing, the reading will be off too.
There are a LOT of different timing tabs that will bolt the the timing chain cover of the SB Chevy but most of them will not be the correct one for the balancer being run because the numbers will be located differently.
Jake
RACE ON!!!
RACE ON!!!
Some companies even make a magnetic bridge that fits across the cylinder and has a built in mount for the dial indicator.
"To me the explanation: To me, that only verifies that 6* on the damper ring is the same as 6* on the timing light dial. I don't see how that indicates whether zero on the damper (or any other number) is being indicated at TDC or not"
6* isn't on the "damper ring" and the damper does not indicate "zero". The groove cut into the dampner is only "supposed" to indicate that the #1 piston is at TDC WHEN that groove is aligned with ZERO on the timing tab. If the groove is aligned with 6 on the timing tab, the mark indicates that the #1 piston is 6 degrees BTDC, and so on. I'm guessing you already know that, but it just wasn't written that way.
I put "supposed" in quotation marks because many times it's not accurate.
Twice I started typing a long explanation on how the dial-back light can be used, but the more I wrote, the more I felt I needed to write. Kinda got out of hand.
Hopefully someone else will post the l o n g version to save me a lot of typing. Besides, I've got to hit the sack so I can get an early start to install my camber brace.
Jake
I suspect my damper ring has rotated and isn't giving a true timing reading. I would like to verify if it is correct, and if not, approximately how far off it is. I do not plan on pulling a head to put a dial indicator on a piston, or to attach a piston stop the the deck. I know how to screw a piston stop into a spark plug hole and mark the damper to find the correct point on the damper that aligns with the 0* mark on the timing tab at true TDC. IF there is a method of accomplishing the same, with a dial back timing light, it seems that would less work and simpler. And I wouldn't have to go buy or make a piston stop. I don't see how, what you originally explained, accomplishes that. Maybe when your not getting ready for bed and your camber brace is installed? Thanks.
RACE ON!!!
