u joints
Old Sep 13, 2004 | 11:39 AM
mothersworry's Avatar
mothersworry
Default u joints
Just got the new ujoints in, however do I need to change the ujoint retainers and bolts? Do you put antisieze or thread lock on these bolts?
Old Sep 13, 2004 | 12:00 PM
fsr402's Avatar
fsr402
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
i use blue locktight on them and have never had any problems.
Old Sep 13, 2004 | 12:02 PM
Corvette0096's Avatar
Corvette0096
Yep, lock tight is all that I use.
Old Sep 13, 2004 | 02:43 PM
mothersworry
Did you replace your existing retainers and bolts?
Old Sep 13, 2004 | 04:17 PM
vsocks's Avatar
vsocks
I have heard some clean up and reuse. Or, you could try these:
http://www.ecklers.com/product.asp?p...WBC7G879KEBK49
Or they have a set of Heavy CNC cryo treated ones for $199.
Old Sep 13, 2004 | 04:32 PM
fsr402's Avatar
fsr402
St. Jude Donor '06
I just reuse them.
Old Sep 13, 2004 | 06:07 PM
-=Iron Mike=-'s Avatar
-=Iron Mike=-
I reused mine; well most of them. I had to drill one out. But I just cleaned the straps up a bit and used some locktite.
BTW, don't over torque these little guys, the older they are the easier they are to strip. I think the spec is like 12 ft. lbs or something.
Old Sep 13, 2004 | 10:36 PM
Wamuscat87's Avatar
Wamuscat87
How do you tell if your U joints are going out. I have been thinking mine are going out because I hear a loud ***** when i put it in drive or reverse. Could that be it. :o
To u joints
