I've been trying to troubleshoot a code 43 and the knock sensor is not the issue. It has been an intermittant that is becoming more and more consistent. I've replaced the connector that goes to the knock sensor and checked the knock sensor operation in datamaster and it is not giving knock counts. I also made sure that the 5V was going to the knock sensor connector with Ignition on.
What are the best things to check next? Is it possible that the 7-pin ignition module is dying?
In your post you say that the knock sensor is not the issue. Did you check the knock sensor itself? It should ohm out to 3300-4500 (on a 1992 anyway). I also chased a code 43 problem and after checking it 4 times it turned out to be a bad knock sensor. Sometimes (as I found out) they can check out o.k.
Thanks for the suggestions. I already checked the knock sensor with an ohm meter - should have mentioned that. The spark module isn't giving a code 42, but I guess it could still be a problem.
The problem started on the way back from a road race track event and it was fairly warm out during the day.
I had the same problem with my 1987. After much checking and with help from this forum I managed to find out that I had two broken wires inside the harness that leads to the esc. Also someone told me to put a new ground wire to the ground wire for the esc. After fixing this I now have no codes and the engine runs like never before. Hope this helps.
i'm getting an intermittant code 43 as well... i've been repairing other things on the car, as this does not seem to be hurting anything... What kind of trouble does this cause?
When knock(pinging) is detected it retards the timming. If the SES light is on and there is something wrong with this circuit, you could be driving without max timing which would make the motor not run at its best.
Or worse if there is pinging and the ecu does not retard timing it can cause serious motor damage.
Going thru the same thing myself. I get a solid 43, not intermittant. I've changed the following:
ECM
Knock Sensor
Electronic spark module in the distributor, because it started as a code 42, changed the module, then the ECM and then it went to code 43
Have now bought a Helms manual, and at this point it has not shed any light.
After I changed the above items and had no success I started looking aroung and found a ground wire broken that was connected on the ground stud at the transmission. Reconnected it and still no help.
The flow chart points to the Prom in the ECM if everything else checks out. I think that maybe that loose ground wire may have damaged it, if no one has any other ideas I may try that. I hate to throw money at it, but I don't know of anything else to do.
An 87 has a ESC, but my 91 does not.
One other thing that is weird, if I disconnect the oil temp sensor, if will not set the code.
The sensor and wiring checks out ok, but when it is connect it works fine, but sets the code 43.
As per the Helms manual, you should show 2.5 volts at the ECM connection A11, which I am.
I had that too. Problem was the pin wasn't good and when I touched the DVOM on it, it would register but when it was mated to the KS, it would not make good contact every now and then and trip the code. I came to this conclusion because I replaced it in desperation and guess what, the code disappeared. I was using my scantool to observe and could even see knock counts and what not while the old plug was in the car. That is what made me think initially that the plug was good.
OK, you talked me into it, I'll try a new connector.
