Disaster at the Chevy Dealership
Old Sep 13, 2004 | 08:19 PM
JF_AH_64's Avatar
JF_AH_64
Default Disaster at the Chevy Dealership (Help Needed!)
I took my car in last week for the standard intake leak and replacement of the water pump. Well I got it back today, on the way home as soon as I pulled of the Interstate I noticed smoke coming from under the hood. When I pulled into my apartment and opened my hood to only to realize that the radiator hose going into the waterpump had sprung a massive leak.
I was wondering what all could have been ruined under the hood, I was thinking the opti-spark (looking for suggestions of other items to check). I also noticed that my power steering was inoperative as well, i could only turn the wheel while moving. What else could have been killed by this massive coolant leak????
The car in on its way back to Chevrolet, so hopefully this will all be taken care of soon.
Thanks for your help.
Old Sep 13, 2004 | 08:25 PM
CFI-EFI's Avatar
CFI-EFI
I hope you made sure that opti was DEAD before you let them take it.
RACE ON!!!
Old Sep 13, 2004 | 08:32 PM
Upstate's Avatar
Upstate
From: [Quote=WOEII] Is dried brown doodie powders man! [/Quote]
I would go back in and .
From your description it seems like numb nutts at the stealership didn't secure your lower radiator hose well enough. It was enough to check for leaks when he was done but after some heating up it probably let go.
I would be demanding a new opti and a free installation. It is not coincidence that the hose came off (I am assuming) the water pump. Don't let'em pull any that well the hose was ready to go and it just happened to occur after the mechanic replaced your pump. I am surprised they didn't recommend you replace the hose to jack up the cost. Stick it to em.
Old Sep 13, 2004 | 09:33 PM
bogus's Avatar
bogus
I guess a dealership is buying you a new optispark.
Old Sep 14, 2004 | 06:15 AM
madmike's Avatar
madmike
New opti, and any other parts damaged. And a rental to drive while they fix their mistake. Takem to small claims afterwards for time off work and stress for good measure. They got the forms online . hehe
Old Sep 14, 2004 | 07:56 AM
runner140*'s Avatar
runner140*
Default Great posts
I couldn't add anything to the above posts.
Old Sep 14, 2004 | 09:42 AM
Vette73's Avatar
Vette73
LS/MFT
St. Jude Donor '09-'10-'11-'12
Better half was reading over my shoulder and suggested you post the name of the dealership so the rest of us can avoid them.
btw: she also wants to know if there's a support group for people who spend too much time on web forums?
Old Sep 14, 2004 | 10:29 AM
byte_me's Avatar
byte_me
btw: she also wants to know if there's a support group for people who spend too much time on web forums? [/QUOTE]
If I heard this once- I have heard it a million times..."you and that Corvette Forum".... try saying that about shoes or purses!
Better sleep with one eye open, or you may be missing a ********!
Old Sep 14, 2004 | 10:31 AM
Upstate's Avatar
Upstate
......support group for people who spend too much time on web forums?
Try Here
Old Sep 14, 2004 | 10:40 AM
ZylaRace's Avatar
ZylaRace
Not to burst your bubble, but why is the shop responsible?
The hose didn't slip off. The opti is still working. And you continued to drive it w/ a "massive" coolant leak. Where did the shop go wrong?
Old Sep 14, 2004 | 11:40 AM
CFI-EFI's Avatar
CFI-EFI
When one PAYS to have a water pump replaced, they have reason to expect that the hoses connected to the water pump will be inspected and the customer adised if addition repairs are necessary. In the case of a hose, I would expect it to be an automatic replacement. Especially at a dealership.
RACE ON!!!
Old Sep 14, 2004 | 06:15 PM
Perfusion's Avatar
Perfusion
RACE ON!!!
*Exactly*...it'd be like paying to have tires mounted/balanced, and on the way home, a wheel/tire falls off at speed because they didn't tighten the lug nuts enough, and then the shop tries to say it's not their fault.
Clearly somebody is at fault, and it's not JF_AH_64 in this case.
Old Sep 14, 2004 | 06:38 PM
JF_AH_64's Avatar
JF_AH_64
Thanks guys for the support, I hope that the dealership will step up and own up to their responsibility in this situation. I am meeting with the service manager tomorrow with hopes of getting this whole situation in order and getting back on the road.
One last thing at the same time I noticed the leak, I lost power steering. I was wondering if this could be in anyway related to the leak or if it was just some crazy coincidence. It seems very unlikely to me that that this would have occurred at the exact same time. Thanks again.
Old Sep 14, 2004 | 06:58 PM
ZylaRace's Avatar
ZylaRace
If the tire fell off, then the dealership would be at fault. But the hose didn't slip off. I can't see it from here, so I can't say how good or bad it looked. If the dealership felt the hose was suspect, they wouldn't hesitate to earn another couple bucks replacing it. (This is a safe bet.)
What you are describing is getting a set of new rubber mounted, then getting a flat on the way home, and somehow the shop is at fault.
Good luck with getting the shop to pony up, but I don't see the dealership is at fault. You need to prove the shop knew the hose would fail, or was damaged in the repair process.
Old Sep 14, 2004 | 07:01 PM
CFI-EFI's Avatar
CFI-EFI
I'D like to know more about exactly WHAT failed. Both in the cooling AND steering systems. It sounds like the belt could have broken, taking the power from the PS pump and cutting the hose???
RACE ON!!!
Old Sep 14, 2004 | 07:04 PM
Chris_G's Avatar
Chris_G
St. Jude Donor '05-'06-'07
Default Plugs and Wires
Man, you guys are making me worry
I'm taking my 94 in Thursday to have NGK plugs and Taylor wires installed. I hope me and the car survive.
Old Sep 14, 2004 | 07:20 PM
JF_AH_64's Avatar
JF_AH_64
I understand what you are saying completely, it is just that I had the car in my possession for no more than 20 minutes before all $#$* broke loose. The leak sprung from directly beside the clamp going to the water pump that had just been replaced. I just find it hard to believe that all this could have happened randomly, but you never know. If it had been today or tomorrow when this occurred I might have just blamed it on bad luck, but I can't help but think they should be somewhat responsible especially given the location of the leak and the timing.
To Disaster at the Chevy Dealership
Old Sep 14, 2004 | 07:23 PM
JF_AH_64's Avatar
JF_AH_64
RACE ON!!!
As far as the belt breaking, I am certain that was not the cause, the leak formed on topside of the radiator hose going into the waterpump. Could the loss of steering power be attributed to belt slippage due to all the coolant being lost???
Old Sep 14, 2004 | 07:27 PM
CFI-EFI's Avatar
CFI-EFI
How can you exonerate the dealer when no one even KNOWS what failed?
A word to the wise...Do it yourself.
RACE ON!!!
Old Sep 14, 2004 | 07:34 PM
arrow322's Avatar
arrow322
sounds like they over tightened the clamp if thats where the leak was
