Using Snap-on Scan Tool Help???
Old Sep 14, 2004 | 04:19 PM
BIZZOMB75's Avatar
BIZZOMB75
4th Gear
Default Using Snap-on Scan Tool Help???
Hello Guys I Think I Found The Problem With My Idle .. Well I Take A Look At The Throttle Body And I Noticed That The Idle Set Screw Is Backed Out All The Way , Its Not Even In Contact With The Arm (i Bought The Car Used) , While Using The Snapon Scan Too I Was Getting
1. 22 Degrees Of Timing At Idle
2. 65 Or So Of Iac
Is This Timing Figure Correct , I Did Not Use A Timing Light , Just The Scan Tool
What Do I Do To Fix The Problem ???
Old Sep 14, 2004 | 04:48 PM
scorp508's Avatar
scorp508
Without a timing light you'll never know if it is right or not. The previous owner could have adjusting the base timing. As far as the ECM is concerned it is at 22*, but it really could be something on either side of that.
Old Sep 14, 2004 | 04:59 PM
bogus's Avatar
bogus
to set the timing on an L98, somewhere near the brake booster is a brown wire with a connector. It must be disconnected prior to starting.
Then use a timing light accordingly.
To Using Snap-on Scan Tool Help???
