IAC question
Old Sep 14, 2004 | 04:29 PM
mikey whipreck's Avatar
mikey whipreck
Default IAC question
Just wondering if someone could tell me the procedure for cleaning or replacing the IAC on my 85 L98?
Old Sep 14, 2004 | 09:57 PM
mikey whipreck
? does my l98 even have one?
Old Sep 14, 2004 | 10:26 PM
aklim's Avatar
aklim
If you have TPI, I would assume you do have an IAC.
Why replace it unless it is bad? I would get gaskets for the TB and the IAC housing. Take the TB off and take the IAC housing off. Clean them all off with brake cleaner. Reinstall. If you have a scantool, goi to the Idle Air Counts screen and adjust the torx screw that does the throttle blades till you have about 10 - 20 counts. After that, set the TPS
To IAC question
