Opti? Code 36? Ways to go? Hellp!!!!!!!
Old Sep 19, 2004 | 07:11 AM
cicch95's Avatar
cicch95
Finalist 2020 C4 of the Year - Unmodified
Originally Posted by John Row
I don't think a 95 cap will fit on an earlier body opti. The connector plug was changed to a better design.
John,
I have read the Corvette Fever article and was thinking of doing it, then I read another artice at www.fierolt1.com (following technical links) and it said that the caps were the same. So, I figured rather than try to fuse the t on to the old cap, Id just swap it out and sell the "old" cap.
Hmmm..now you have me thinking. Ahhhh..
-Rick
Old Sep 19, 2004 | 08:16 PM
John Row's Avatar
John Row
Actually, I think the top (or front, depending on your perspective) will fit. The middle part that mates with the base won't.
Come to think of it, that might be enough to get the vent line into the opti. The outlet vents are in the metal body.
Old Sep 20, 2004 | 09:48 AM
93Quasar's Avatar
93Quasar
Man, I took a peek at this post yesterday, and it jinxed me. I was driving last night and it just dies. Finally got it to run long enough to get home and I have code 16. Cleared the code. Thought I'd try my luck this morning and it is still acting up. Now I have both code 16 and code 36. 2nd opti this year.
Not 5 minutes before it acted up last night I engaged in some "spirited driving" with a stang in the next lane over. Do high rpms damage the opti? I'm curious also if the Dynaspark is proven to be better than the stock opti. And it makes it hard to jump to the DelTeq when I still have to replace the opti also.
