Old Mar 6, 2015, 12:34 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension How-Tos
Print Wikipost
96 front Leaf Spring removal...how to ..
Old Sep 15, 2004 | 09:59 PM
collectorvette96's Avatar
collectorvette96
1st Gear
Default 96 front Leaf Spring removal...how to ..
ok here's the deal, I got a 96 collector here and got the dropping kit to drop it an inch. it says in the directions to get a leaf spring compressor tool from GM. Who out here has done this mod and what do I have to look forward to? do I really need this spring compressor? does this spring have this much tension on it that I can't get it out or in without the tool? thanks!!!!!!
Graig
84, 96
Old Sep 15, 2004 | 11:58 PM
Gary04Z06's Avatar
Gary04Z06
I didn't use a tool, just used a floor jack to on the bottom of the a-arm, couple of pumps, undid the mouning bolts, slowly lowered the jack to release the pressure. It takes some time to do it, but a good do-it-your-selfer can do it.
Old Sep 16, 2004 | 08:52 AM
purplemajesty's Avatar
purplemajesty
Here's a good writeup on how it should be done:
http://webpages.charter.net/khasting.../lowering.html
Now would also be the ideal time for the poly bushings if you are at all inclined.
Old Sep 16, 2004 | 09:05 AM
jerkyboy's Avatar
jerkyboy
Just make sure you use a block of wood between the a arm and the jack as the aluminum mars easily. Also, it a good time to replace lower ball joints if needed. I just took the A arms out and took them to Midas and they pressed out the old ones and pressed in the new ones.
To 96 front Leaf Spring removal...how to ..
