stock starter on 88
RACE ON!!!
1.) Simply install an offset bolt pattern, starter for a 168 tooth flexplate.
2.) Drill the third hole, and use an aftermarket mini starter.
3.) Drill the third hole. Switch to a 153 tooth flexplate, and use the OE mini starter you have.
The problem with option 1.) is that you are using a large starter, spaced outward, for the large flexplate. That causes more clearance and heat problems. I am ASSUMING the small starter you have is an OE starter. If that starter has 4 mounting holes, all in a row, it is the aftermarket mini starter, and will work for option # 2.). See ya in the spring.
RACE ON!!!
