Part # for tach filter?
Old Sep 18, 2004 | 09:53 PM
evitagenone's Avatar
evitagenone
Default Part # for tach filter?
I need the GM Part number for the tach filter for a 89. Mine has seen better days.
Old Sep 18, 2004 | 10:16 PM
eptaylor's Avatar
eptaylor
As I recall someone put the specs for the capacitor on the forum within the last 6 or 7 months. I saw one advertised somewhere for a whopper of a price. If no one chimes in on this I will measure mine and find you a replacement for only a buck or two I would guess. It is just a simple capacitor and the application is nothing special or secret, it is just a RIP OFF to pay more for one.
Old Sep 18, 2004 | 10:34 PM
eptaylor's Avatar
eptaylor
As I recall someone put the specs for the capacitor on the forum within the last 6 or 7 months. I saw one advertised somewhere for a whopper of a price. If no one chimes in on this I will TRY to measure mine and recommend a replacement for only a buck or two I would guess. It is just a simple capacitor and the application is nothing special or secret, it is just a RIP OFF to pay more for one.
Old Sep 18, 2004 | 11:33 PM
Corvette0096's Avatar
Corvette0096
Old Sep 19, 2004 | 03:36 PM
CFI-EFI's Avatar
CFI-EFI
1984 - 1990, 14093115.
Race On!!!
Old Sep 19, 2004 | 04:45 PM
DANSURE1's Avatar
DANSURE1
Default Not Sure
Are you saying your tach not working, My 90 won't work i need help to i don't no what a filter for one is ?
Old Sep 20, 2004 | 07:03 PM
eptaylor's Avatar
eptaylor
It is a capacitor that filters out electronic noise such as high frequency spikes, etc. If your tach does not work it probably isn't the filter but could be if the filter is shorted internally. Bad filters should only cause the tach to float around and not track rpm well because it is trying to also follow random noise.
Old Sep 20, 2004 | 07:37 PM
CFI-EFI's Avatar
CFI-EFI
I broke a wire off of mine this spring, during one of my three intake manifold R&Rs. I hooked the wire up direct, without the filter and the tach works as well, or better, without the filter.
RACE ON!!!
Old Sep 26, 2004 | 04:31 AM
85blkrose's Avatar
85blkrose
think i need one as well, tach worked fine till i put in a hight output coil and ignition module. now when i get on it works fine till 3800-4000 then it goes nuts and jumps all over
Old Sep 26, 2004 | 11:09 AM
CFI-EFI's Avatar
CFI-EFI
You've got the part number.
RACE ON!!!
To Part # for tach filter?
