Susepnsion upgrade
Old Sep 19, 2004 | 05:25 PM
Kurac's Avatar
Kurac
Default Susepnsion upgrade
I'm looking to eventually upgrade the suspension on my 93 6-spd coupe. It has the base suspension setup. During high speed spirited driving the car doesn't feel as buttoned down as I would like. I'd like to get some opinions on a suspension set up.
P.S. It has ZR-1 rims and new Goodyear Eagle F1 tires (275's at each corner) as well as Baer rotors on all corners and C5 calipers on the front already.
Old Sep 19, 2004 | 05:30 PM
aeronautica86's Avatar
aeronautica86
http://www.madvet.com/shop?frame=3.148.3905
Old Sep 19, 2004 | 06:04 PM
Kurac's Avatar
Kurac
This is the type of package that I'm looking for. Any one know what type of lateral G's this setup pulls?
Old Sep 19, 2004 | 06:14 PM
aeronautica86
I highly doubt that its ever been tested....it'll be better than your base setup....but you'd also feel a huge improvement if you just replaced all the worn out parts in your current setup
Old Sep 19, 2004 | 06:25 PM
Kurac's Avatar
Kurac
car only has 23K miles. I would think there wouldn't be anything worn out already.
Old Sep 19, 2004 | 06:43 PM
aeronautica86
rubber + time = bad suspension
Old Sep 21, 2004 | 02:33 PM
silver & red CE's Avatar
silver & red CE
I had the same basic suspensionas you did. I kept the stock springs, upgraded the swaybars to 30mm/26mm solids with poly bushings and endlinks. After that my Vette cornered much flatter.
Eric
Old Sep 21, 2004 | 11:00 PM
Gary04Z06's Avatar
Gary04Z06
Upgrade to a 30mm solid frt sway bar, better springs, http://www.vbandp.com/ has some great packages. Then get the Camber Brace from www.r-dracing.com, and their Cross Bar, or better yet, the S/T Frame Support (see sig).
Old Sep 21, 2004 | 11:11 PM
John Row's Avatar
John Row
Originally Posted by silver & red CE
I had the same basic suspension as you did. I kept the stock springs, upgraded the swaybars to 30mm/26mm solids with poly bushings and endlinks. After that my Vette cornered much flatter.
Eric
This made a huge difference in handling. No more exciting exits from bumpy corners.
Old Sep 21, 2004 | 11:22 PM
lawcorvette's Avatar
lawcorvette
Ladimer,
I saw that package as well when I redid my suspension. I redid all the bushings and ball joints, made the switch to coil overs, VBandP smart struts, and heim links, and went with the 30 mm/26 mm sway bars instead of the package in mid america.
The reason for this is I got deals on almost everything (ebay and this forum) but the coil overs (which weren't much more than new springs and bilsteins) and TAKE A LOOK AT THE PRODUCT REVIEW FOR VETTE BRAKES AND PRODUCTS EXTREME TOURING SYSTEM on this web site. When I was in the market they got a terrible product review and it looks to be the same thing.
I can't tell you how my set up is going because I am still building the car but I sure help it was worth the effort.
Old Sep 21, 2004 | 11:30 PM
lawcorvette
Sorry the product review is titled:
Vette Brakes and Products C4 Sport Suspension Kit and Rebuild Kit
To Susepnsion upgrade
