roller rockers??
Old Sep 19, 2004 | 09:32 PM
6spd's Avatar
6spd
Default roller rockers??
hey guys, what are good roller rockers to get i mean what brand?? do i have to buy the best to last or are there some others. i will be going with 1.6"s also should i go with align or non align and any advantage. oh i have a 91 vette. thanks
Old Sep 19, 2004 | 10:10 PM
C4Crazy787's Avatar
C4Crazy787
Check out this thread
http://forums.corvetteforum.com/showthread.php?t=905601
You could also do a search on the topic, I've got GMPP 1.6RR's.
Old Sep 19, 2004 | 11:17 PM
TA's Avatar
TA
I have 1.6 Comp Cams Pro Magnums in my 91 and have been very happy with them.
Old Sep 20, 2004 | 07:21 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Your '91 has self aligning stamped rockers with non functional and non hardened guide plates and non hardened pushrods.
Since you need to pull the rocker arm studs to remove those guide plates anyway I suggest you go with:
-1.6:1 non self aligning ProMagnums for 7/16" studs
-ARP 7/16" studs
-hardened guide plates
-hardened push rods
The overall cost should be about the same as going with self aligning RRs and about the same amount of work, or less.
You can get the ARP studs from Summit and the rest of the components from Summit or Comp Cams directly.
Don't foreget to use a little light assembly lube on the ends of the push rods and on the valve tips to aid break in.
Old Sep 20, 2004 | 10:55 AM
Red Tornado's Avatar
Red Tornado
I agree with 65Z01, his advice is dead on
Old Sep 20, 2004 | 01:13 PM
TA's Avatar
TA
Hmmm, my 91 did not have guide plates, functional or otherwise
Old Sep 20, 2004 | 08:27 PM
RadPolo96's Avatar
RadPolo96
Comp Pro Mags are great, I havent had any probs with them either.
Old Sep 21, 2004 | 02:14 AM
JAKE's Avatar
JAKE
-ARP 7/16" studs
-hardened push rods
Jake
To roller rockers??
