Back-up Lights
Old Sep 19, 2004 | 11:34 PM
mik's Avatar
mik
Default Back-up Lights
My back-up lights decided to quit working. Any ideas what to look for?
I have a 94 with a six speed.
Thanks.
Old Sep 20, 2004 | 12:13 AM
skateparkdave's Avatar
skateparkdave
St. Jude Donor '05-'06
Your six speed has a backup switch, up high on drivers side near top left bolt of the five bolts that hold tranny to clutch housing, that may be bad. Check the wiring to it and the switch. I think you should be able to check switch by unplugging the wire harness and jumper it with a paper clip with your key forward and lights should come on. If they do the switch is probably bad.
Old Sep 20, 2004 | 12:21 AM
skateparkdave
Also, I was assuming you've already checked fuses in the above post. If your turn signals also dont work, it may just be a fuse.
To Back-up Lights
