best tool for dist adjustment bolt?
Old Sep 20, 2004 | 12:21 PM
Square's Avatar
Square
Default best tool for dist adjustment bolt?
Hi Guys,
I searched for this and couldn't find anything. I want to check my timing, and if I need to adjust it, I want to know if I need a special wrench to get to the distributor hold down bolt. I looked at it, and it looks like it is under the distributor cap. What is the best tool/technique for this?
Thanks!
Old Sep 20, 2004 | 12:32 PM
95AquaC4's Avatar
95AquaC4
Originally Posted by Square
Hi Guys,
Thanks!
You should be able to grab a distributor wrench at Sears pretty inexpensively. They are special wrenches for this. Perhaps some simple swivel sockets may get the job done, but I've always had the proper wrenches.
Old Sep 20, 2004 | 12:47 PM
85blkrose's Avatar
85blkrose
i picked one up at the local auto store. autozone,pep boys,parts
america. any of these place should have one
Old Sep 20, 2004 | 12:50 PM
Red Tornado's Avatar
Red Tornado
I got mine at Advance Auto, I think it was about $5. The Sears version would be better quality though.
Old Sep 20, 2004 | 12:51 PM
Square's Avatar
Square
Thanks guys!
What size do I need to get?
Old Sep 20, 2004 | 01:02 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The one from Sears comes with two sizes, don't recall which one fits my SBD dist.
Red Tornado
just tell them you want a dist. wrench for small block chevys....they have 2 ends, I believe we would use the 9/16" end.
Old Sep 20, 2004 | 01:24 PM
TA's Avatar
TA
A little pricey, but SnapOn makes a fantastic dist. wrench
Old Sep 20, 2004 | 01:48 PM
bogus's Avatar
bogus
you don't want the cheapy ones... they have this funky socket thing in the middle, and what happens is that is falls apart at the least opportune moments!
Get the sears one, and get the bigger one from sears. I think it's 9/16th, I can measure if you like, cause I have one for bastet44s 87 coupe!
Old Sep 20, 2004 | 03:01 PM
Square's Avatar
Square
Thanks guys!
I will get the Sears tool. Most of you guys are recalling 9/16ths as the correct size. I will see if I can get a 9/16ths socket or box wrench on the bolt to confirm before I buy.
Thanks again!
Old Sep 20, 2004 | 05:08 PM
Vetterin's Avatar
Vetterin
Yep, that will do it.
Old Sep 21, 2004 | 10:32 AM
MrRenoman's Avatar
MrRenoman
Even the inexpensive tool works ok. As far as technique goes; I remove the fastener that's holding the solenoid between the RH valve cover and the distributor. This allows the wrench to rotate when loosening the distributor bolt. You don't want to damage this solenoid especially since the vacuumn lines are connected on the end the wrench wants to push against. The solenoid fittings to the hose are plastic and can break easily. I'm not sure about the later years but this is what I've found on the early L98s.
Art
Old Sep 21, 2004 | 10:40 AM
Wheelman's Avatar
Wheelman
Anyone have a pic? I would like one to bring with me to adjust my timing between runs at the track
Old Sep 21, 2004 | 01:39 PM
bogus's Avatar
bogus
hm... for some reason, Sears thinks that one should by a boring bit when buying this tool... odd.
To best tool for dist adjustment bolt?
