new shocks ride high
Old Sep 21, 2004 | 09:42 PM
blown66's Avatar
blown66
Default new shocks ride high
Just put new gas shocks on rear of my 92 coupe and it stands up a LOT higher. Do they eventaually settle down? I checked the length against the old Delco's and they are the same. It is not adjustable shocks or ride controlled car. If the front does this it will look like a jacked-up 4 wheeler.
Old Sep 21, 2004 | 10:29 PM
eschoendorff's Avatar
eschoendorff
St. Jude Donor '08
Old Sep 22, 2004 | 12:35 AM
howdo's Avatar
howdo
Default you gots to drive it around
I had the same question when I put on my shocks. Once you drive the car around, the ride height will return to normal.
cheers,
Howdo
Old Sep 22, 2004 | 08:16 AM
Steel Blue 91's Avatar
Steel Blue 91
cheers,
Howdo
You'll need to drive on them. You should be back to where you had it shortly.
Old Sep 23, 2004 | 08:52 PM
blown66's Avatar
blown66
Hey! Thanks guys. The origanl brakes and shocks were on this car. It rides and stops like a dream now.
To new shocks ride high
