Question about 11" rear wheels
They may help in your case then. Rims/tires are considered unsprung weight. For every 1 pound of unsprung weight you add it is sort of figured to be what ~2.5 pounds of sprung weight would be. The 'ballpark' figure is that 100 pounds of sprung weight will slow you down by 0.1 seconds. If you weigh your new setup and subtract your old ones you should be able to get an approximate.
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
I slowed down quite a bit, couple tenths.
