LCD Panel shorting? Flashing? on '85
Old Sep 21, 2004 | 10:13 PM
MrNuke's Avatar
MrNuke
Default LCD Panel shorting? Flashing? on '85
I had my LCD cluster re-built about 3-4 years ago, and I've noticed over the past few months it is flashing.
If left in Park or idling, it doesn't flash at all, but when I drive it around and push on the gas, it flashes, kind of like blinking all the lcd's on/off.
It does this more when the car is cold vs w hen it's warmed up..
Wierd. I wonder if I have a spark plug that is shorting, or the tach line's shorting to ground or something.. I have spliced into the tach line at the distributor end where I have attached my analog tach..
Anyone have any ides?
Old Sep 21, 2004 | 10:50 PM
mikey whipreck's Avatar
mikey whipreck
mine did that... the clusters' on board power supply was shot... You could check all your grounds though, that's free, and not too difficult...
Old Sep 21, 2004 | 11:25 PM
Corvette0096's Avatar
Corvette0096
Make sure that your battery cables are tight. Happen to me.
Old Sep 22, 2004 | 07:40 AM
Kenwood's Avatar
Kenwood
Mine did that too> but I took it apart and noticed that the PINS between the 2 boards>>the ones that send signals from the backto the front board were lightly corroded...I hit them carefully with contact cleaner and all was gone.. hopefully you get lucky like I did..
Old Sep 22, 2004 | 08:32 PM
MrNuke's Avatar
MrNuke
Ok, cool.. Look slike I'll be tearing teh dash apart over the weekend..
Thanks everybody..
To LCD Panel shorting? Flashing? on '85
